0 Replies Latest reply on Sep 24, 2008 10:07 AM by (Carol_Frampton)
    [svn] 3331: Update FABridge (Flash Authoring Bridge) sample apps.
    Level 1
      Revision: 3331
      Author: cframpto@adobe.com
      Date: 2008-09-24 11:07:44 -0700 (Wed, 24 Sep 2008)
      Log Message:
      - convert to use swfobject
      - run validator on html files and cleanup errors
      - get rid of multiple copies of the same file which is just plain bad
      - generate zip which goes with srcview app so the contents are current and usable
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/FABridgeSample.html
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/SimpleSample.html
      flex/sdk/trunk/templates/swfobject/index.template.html
      Added Paths:
      flex/sdk/trunk/frameworks/javascript/build.xml
      Removed Paths:
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/fabridge.zip
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/source/FABridgeSample.html
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/source/FABridgeSample.js
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/source/SimpleSample.html
      Property Changed:
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/source/fabridge/
