0 Replies Latest reply on Jul 3, 2006 6:34 AM by Mr Binitie
    Probable bug with the Video Class
    Mr Binitie
      I have 2 Flex2 custom components. Each component contains an instance of the Video class within a UIcomponent wrapper. One of the components;
      <aYo:ShowThem x="0" y="25" width="300" height="250" id= "showthem"/>captures the a camera feed and publishes, the other;
      <aYo:SeeThem x="0" width="348" height="306" y="25" id= "seethem"/>
      plays back what the live stream.
      Elementary I can hear you all say.
      Here comes the twist,
      <ShowThem> has its video aspect ratio set to
      videoHolder = new UIComponent();
      v1 = new Video(80, 60);
      videoHolder.setActualSize(90, 90);
      videoHolder.addChild(v1);
      <SeeThem> is set as follows
      v2 = new Video(200, 150);
      videoHolder.setActualSize(200, 150);
      videoHolder.addChild(v2)
      In the main mxml, we have;
      **When published, the video class instance in SeeThem v2 now takes the same size of the video class instance in ShowThem v1. If on the other hand you layout the tags in reverse e.g.
      *** The reverse happens i.e. The video class instance in now ShowThem v1 takes the same size of the video class instance in SeeThem v2
      In conclusion it seems that if you have 2 different components with video objects, the video size of all video objects will be determined by the size of the video class instance in the last tag.
      Is this so??
      [a /]
