1 Reply Latest reply on Sep 16, 2004 8:44 AM by (Rick_Cananus)
    Multiple Email Configurations
      I have the server successfully converting a standard configuration, and I can use a different job options file for different parameters.
      How can I configure the Elements Server so that it checks multiple email accounts, each of which uses a different set of job options?
      To clarify:
      PDF Write mailbox receives jobs which will use the default joboptions file
      PDF Protect mailbox receives jobs that require a password to edit
      PDF Noprint mailbox receives jobs that cannot be printed
      etc
      Ralph
        • 1. Re: Multiple Email Configurations
          You would setup job configurations files for each of the different settings, then specify additional email sources in aaes.xml.  The additional sources would reference the specifc job configuration file.  See below for a sample.<br /><br /><?xml version="1.0" encoding="UTF-8" standalone="yes"?><br /><client destination="out" staging="$(root)/data/staging" jobconfig="Standard" delay="3"><br /><br />    <jobconfig name="Standard" path="$(root)/cfg/Standard.xml"/><br />    <jobconfig name="Secure" path="$(root)/cfg/Secure.xml"/><br />    <jobconfig name="A6Forms" path="$(root)/cfg/SecureA6.xml"/><br /><br />    <source name="in"  type="folder" path="$(root)/data/watchedfolder/in" preserve="true"<br />            preservedestination="preserved" preservefaildestination="failed"<br />            purgetime="3600" purgedestination="purged"/><br /><br />    <source name="webservice" type="soap" path="$(root)/data/soap/in" destination="webservice"/><br /><br />    <source name="email1" type="pop3" path="$(root)/data/email1/in" host="company.com"<br />            user="username" pass="password" accept="company.com"<br />            destination="email1" jobconfig="Standard" maxfilesize ="10MB" timeout="2" throttle="60"/><br />    <br />    <source name="email2" type="pop3" path="$(root)/data/email2/in" host="company.com"<br />            user="next username" pass="password" accept="company.com"<br />            destination="email2" jobconfig="Secure" maxfilesize ="10MB" timeout="2" throttle="60"/><br /><br />    <source name="email3" type="pop3" path="$(root)/data/email3/in" host="company.com"<br />            user="next username" pass="password" accept="company.com"<br />            destination="email3" jobconfig="A6Forms" maxfilesize ="10MB" timeout="2" throttle="60"/> <br />    <br />    <source name="webui" type="http" path="$(root)/data/webui/in" jobconfig="Standard, Secure, A6Forms" maxfilesize ="10MB"<br />            destination="webui"/><br /><br />    <destination name="out" type="folder" path="$(root)/data/watchedfolder/out"/><br />    <destination name="failed" type="folder" path="$(root)/data/watchedfolder/failed"/><br />    <destination name="preserved" type="folder" path="$(root)/data/watchedfolder/preserved"/><br />    <destination name="purged" type="folder" path="$(root)/data/purged"/><br />    <destination name="webservice" type="soap" path="$(root)/data/soap/out"/><br /><br />    <destination name="email1" type="smtp" path="$(root)/data/email1/out" host="company.com"<br />                 returnname="Adobe Acrobat Elements Server" returnaddress="email@company.com"<br />                 recipient="sender" defaultsubject="RE: Your AAES E-mail Request for Standard pdf"<br />                 maxfilesize="10MB" timeout="2"/><br /><br />    <destination name="email2" type="smtp" path="$(root)/data/email2/out" host="company.com"<br />                 returnname="Adobe Acrobat Elements Server" returnaddress="email@company.com"<br />                 recipient="sender" defaultsubject="RE: Your AAES E-mail Request for Secured pdf"<br />                 maxfilesize="10MB" timeout="2"/><br /><br />    <destination name="email3" type="smtp" path="$(root)/data/email3/out" host="company.com"<br />                 returnname="Adobe Acrobat Elements Server" returnaddress="email@company.com"<br />                 recipient="sender" defaultsubject="RE: Your AAES E-mail Request for Secured Adobe 6 pdf"<br />                 maxfilesize="10MB" timeout="2"/><br /><br />    <destination name="webui" type="smtp" path="$(root)/data/webui/out" host="company.com" <br />                 returnname="Adobe Acrobat Elements Server" returnaddress="email@company.com"<br />                 recipient="sender" defaultsubject="Your AAES Web Request"<br />                 maxfilesize="10MB" timeout="2"/><br /><br />    <validator name="doc" type="word"/><br />    <validator name="xls" type="excel"/><br />    <validator name="ppt" type="powerpoint"/><br />    <validator name="ps"  type="ps"/><br />    <validator name="eps" type="eps"/><br />    <validator name="rtf" type="rtf"/><br />    <validator name="txt" type="txt"/><br />    <validator name="ascii" type="ascii"/><br />    <validator name="tif" type="tif"/><br />    <validator name="jpg" type="jpg"/><br />    <validator name="bmp" type="bmp"/><br />    <validator name="gif" type="gif"/><br />    <validator name="psd" type="psd"/><br />    <validator name="wpd" type="wpd"/><br />    <validator name="vsd" type="visio"/><br />    <validator name="mpp" type="msproject"/><br />    <validator name="dwg" type="autocad"/><br />    <validator name="pdf" type="pdf"/><br /><br />    <slot name="slot-01"<br />          validator="doc,xls,ppt,ps,eps,rtf,txt,ascii,tif,jpg,bmp,gif,psd,wpd,vsd,mpp,dwg,pdf"><br />      <sources>email1,email2,email3,webui</sources><br />    </slot><br /><br />    <template name="smtp-success" path="$(root)/template/smtp-success.tmpl"/><br />    <template name="smtp-failure" path="$(root)/template/smtp-failure.tmpl"/><br />    <template name="smtp-failure-attachsize" path="$(root)/template/smtp-failure-attachsize.tmpl"/><br />    <template name="smtp-failure-convertsize" path="$(root)/template/smtp-failure-convertsize.tmpl"/><br />    <template name="webui-help"   path="$(root)/template/webui-help.html"/><br />    <template name="webui-result" path="$(root)/template/webui-result.html"/><br />    <template name="webui-submit" path="$(root)/template/webui-submit.html"/><br /><br /></client>
