2 Replies Latest reply: Jan 6, 2009 1:17 PM by alan ruta RSS
    Distill fail if rgb files placed
    alan ruta Community Member
      Is there a way/setting in which the distil will fail if an rgb file is placed?
      thanks
      alan
        • 1. Re: Distill fail if rgb files placed
          Steve Werner CommunityMVP
          If your workflow still uses the old Distiller workflow, run a Preflight check after distilling looking for RGB images.
          Better if you're working with Adobe Creative Suite files (InDesign, Illustrator, Photoshop) is to export or save directly as PDF choosing PDF/X as the PDF preset. This will convert the RGB to CMYK.
          • 2. Re: Distill fail if rgb files placed
            Thanks.
            I can set it up distilling or exporting to convert rgb to cmyk. I rather the distilling "cancel", or exporting fail with a message that there are rgb files.
            Different clients tiff files use different profiles. If the wrong 4c profile or and rgb profile is used I want the error.
            I realize I can preflight with ID but I'd rather skip that step for the rare occasion the wrong profile has been converted to.
            alan
