28 Replies Latest reply on Sep 15, 2008 11:18 AM by (Leonard_Rosenthol)
      • 12. Re: How to save as "optimized" using IAC
        (Aandi_Inston) Level 1
        >- is it possible to call an Acrobat plug-in from a VB6 program ? (I saw that a plug-in is an .api file rather than a .dll)
        Not directly. A plug-in is loaded by Acrobat, and Acrobat allows the
        plug-in to register menu items, tool buttons and so forth. So it is
        Acrobat that calls the plug-in, always.
        It is possible for an external program to ask Acrobat to run a menu
        item, and so run part of a plug-in. But passing parameters is a
        separate issue - for example you could put parameters into a file.
        >- do PDF Optimizer functions like AVDocSaveOptimized can be called from a C/C++ standalone application ?
        The Acrobat SDK cannot be used to make standalone applications:
        Acrobat always does the work. The methods available to you are IAC,
        which can be a standalone executable using Acrobat, and plug-ins,
        which are part of Acrobat. AVDocSaveOptimized is only in the plug-in
        API.
        Aandi Inston
        • 13. Re: How to save as "optimized" using IAC
          Hi folks,
          So, the way to go in this would be to create a plugin that saves a file as optimised. This plugin would register a menu item and this menu item could be called from the VB or C# app via Acrobat API. Right?
          In this scenario, would it still be possible to have a single installer file for the PDF optimiser tool? That is which also installs the Acrobat plugin?
          Kind regards,
          Martin
          • 14. Re: How to save as "optimized" using IAC
            This should work. You still have to consider what back door would be
            used to pass parameters, or whether you need parameters (for example
            it could just act on the currently open front document).
            You mean, could you write an installer that installed an executable,
            and also a plug-in, given that someone has already purchased abnd
            installed Acrobat? I don't see why not, but bear in mind that the
            location for the Acrobat plug_ins folder is not fixed.
            Aandi Inston
            • 15. Re: How to save as "optimized" using IAC
              Level 1
              Hi I am reading the PDF files programmatically using C# , here I am suffering from the reading order in PDF files, as at the some places its column wise and some places its plain text read in line.
              I want to know if there is any the solution for the making the reading order correct in PDF files (it should be left to right and Top to bottom).
              Touchup text tool makes this task. Does anybody know how to get the touch up tools functionality though program using c# or VB.net?
              • 16. Re: How to save as "optimized" using IAC
                Level 1
                left->right, top->bottom is only true for Roman language documents. For Hebrew or Arabic, for example, it's right->left. For Chinese or Japanese, it may be top->bottom, left->right (for vertical text).
                If you are planning to do text extraction on PDF, there is a LOT of complexity involved...
                Leonard
                • 17. Re: How to save as "optimized" using IAC
                  I'm lost on this, as well. How, programmatically, do you optimize? I will be running this process as an automated service, so menu items would be out of the question. It will be a .net windows service that scans a directory, appends the PDFs and optimizes them. How do I go about doing this?
                  • 18. Re: How to save as "optimized" using IAC
                    Actually, you can automate menu items. But if they display a dialog,
                    that can't be suppressed.
                    You don't do this with the Acrobat SDK, I don't think the license
                    would allow it.
                    Aandi Inston
                    • 19. Re: How to save as "optimized" using IAC
                      Level 1
                      how do you automate menu items if not through the SDK? the CreateObject call invokes Acrobat.exe...
                      • 20. Re: How to save as "optimized" using IAC
                        Level 1
                        I think you missed something, Stephen...
                        Acrobat is NOT LICENSED (nor is it technically suitable) for use in an automated/unattached/service environment.
                        • 21. Re: How to save as "optimized" using IAC
                          Level 1
                          I tried this:
                          Dim outDoc As CAcroPDDoc
                          Dim App As CAcroApp
                          Dim inDoc As CAcroPDDoc
                          Dim outputFileFullPath As String
                          Dim inputFileName As String
                          Dim i As Integer
                          'Dim fileNames(PDFfiles.Count - 1) As String
                          Dim xmlFileName As String
                          Dim w As String, x As String, y As String, z As String
                          Dim numInPages As Integer, numOutPages
                          Dim retval As Integer
                          Dim tempFileName As String
                          Dim xmlFile As String
                          Dim processAcrobat() As Process
                          Dim trialAttempts As Integer = 6
                          Dim triedAttempts As Integer
                          Dim finishedOptimization As Boolean
                          Dim killedAcrobat As Boolean
                          Dim BRetval As Boolean = False
                          Dim AcrobatJava As Object
                          'Dim pp As VariantType
                          'For i = 0 To PDFfiles.Count - 1
                          ' fileNames(i) = PDFfiles(i)
                          'Next i
                          If PDFfiles.Count = 0 Then
                          'FileSet.LogMessage("No files were found for this set. Output File was going to be " & outputFileName)
                          Exit Function
                          End If
                          tempFileName = Path.Combine(outputDir, "temp.pdf")
                          If PDFfiles.Count > 1 Then
                          Try
                          'outDoc.New(outputFileFullPath)
                          outDoc = CreateObject("AcroExch.PDDoc")
                          App = CreateObject("AcroExch.App")
                          App.Hide()
                          'outDoc.Open(outputFileName)
                          File.Copy(PDFfiles(0), PDFfiles(0) + ".tmp", True)
                          outDoc.Open(PDFfiles(0) + ".tmp")
                          For i = 1 To PDFfiles.Count - 1
                          inDoc = CreateObject("AcroExch.PDDoc")
                          inputFileName = PDFfiles(i)
                          retval = inDoc.Open(inputFileName)
                          'outDoc.Attach(inDoc)
                          'outDoc.InputCopyAll()
                          numOutPages = outDoc.GetNumPages() - 1
                          numInPages = inDoc.GetNumPages()
                          retval = outDoc.InsertPages(numOutPages, inDoc, 0, numInPages, -1)
                          inDoc.Close()
                          inDoc = Nothing
                          'File.Copy(inputFileName, outputDir & "/" & CStr(i) & ".pdf")
                          Next i
                          'outDoc.Close()
                          AcrobatJava = outDoc.GetJSObject()
                          App.Hide()
                          Dim pp As Object = AcrobatJava.getPrintParams()
                          pp.fileName = "file://c/ftp_stream/example/myDoc.ps"
                          pp.printerName = ""
                          AcrobatJava.print(pp)
                          'App.Show()
                          'App = Nothing
                          AcrobatJava = Nothing
                          outDoc.Save(Acrobat.PDSaveFlags.PDSaveFull + Acrobat.PDSaveFlags.PDSaveCollectGarbage + Acrobat.PDSaveFlags.PDSaveLinearized, Path.Combine(outputDir, outputFileName)) 'Path.Combine(outputDir, "final.pdf"))
                          outDoc.Close()
                          outDoc = Nothing
                          BRetval = True
                          Catch ex As Exception
                          'FileSet.LogMessage("Error Message 1007: Error concatenating Pdf Files for inputfile " & inputFileName & " OutputFile=" & outputFileName & " Error is " & Err.Description)
                          BRetval = False
                          Finally
                          outDoc = Nothing
                          Do Until killedAcrobat Or triedAttempts = trialAttempts
                          Try
                          processAcrobat = System.Diagnostics.Process.GetProcessesByName("Acrobat")
                          For i = 0 To processAcrobat.GetLength(0) - 1
                          processAcrobat(i).Kill()
                          Next
                          triedAttempts = triedAttempts + 1
                          If File.Exists(inputFileName + ".temp") Then
                          File.Delete(inputFileName + ".temp")
                          System.Threading.Thread.Sleep(1000)
                          End If
                          killedAcrobat = True
                          Catch exException As Exception
                          killedAcrobat = False
                          End Try
                          Loop
                          End Try
                          Else
                          File.Copy(PDFfiles(0), outputFileName, True)
                          End If
                          When I get to "getPrintParams" it pops up a dialogue window. How do I get it to not do that?
                          • 22. Re: How to save as "optimized" using IAC
                            Level 1
                            You don't. It WILL do that.
                            Please re-read my message concerning Acrobat NOT being suitable (or legal) to be run in the environment you wish...
                            Leonard Rosenthol
                            Adobe Systems
                            • 23. Re: How to save as "optimized" using IAC
                              please provide a sample in c++ of how to call AVDocSaveOptimized specifying the header files, references, settings...
                              thanks
                              • 24. Re: How to save as "optimized" using IAC
                                Why? When you use the plug-in wizard it sets up the things you need.
                                Aandi Inston
                                • 25. Re: How to save as "optimized" using IAC
                                  Level 1
                                  In adobe there is a function by which you can right click on a group of files, and choose to concatenate them, with a menu option for making the file size smaller. I have tried to scour the documentation for a way to automate this, and have found nothing. Is this at all possible through the SDK?
                                  • 26. Re: How to save as "optimized" using IAC
                                    There is no API directly to this "convert and combine" function. Using
                                    JavaScript, I _think_ you can convert (may be wrong - might need a
                                    plug-in). There are then various methods of combining.
                                    Aandi Inston
                                    • 27. Re: How to save as "optimized" using IAC
                                      Level 1
                                      What's odd is I found a way to combine the PDFs, then save as postscript then distill, but it takes 12 hours, mostly the PDF conversion. the combine and shrink takes about 5. I essentialyl just need a way to shrink the PDF without making postscript of it.
