This content has been marked as final.
Show 6 replies
1. Re: One question about Form XObject and Illustrator View Outline mode
(Leonard_Rosenthol) Nov 6, 2008 9:07 AM (in response to andrejusc)Adobe Illustrator is NOT a PDF editor.
When you open a PDF in Illustrator it converts the PDF into its own internal representation which does not necessary reflect all the internal details of the PDF.
Leonard -
2. Re: One question about Form XObject and Illustrator View Outline mode
andrejusc Nov 6, 2008 11:07 AM (in response to andrejusc)Hi Leonard,
Thank you for pointing me that. Yes, Illustrator is not aPDF editor, but if someone knows what exactly is shown from PDF in Illustrator when View/Outline mode is activated - I could probably think about what needs to be done for my Form Xobject entries (even some additional refactoring of them into not embedded paths as they are right now in my case) to be visible/hidden in a way my customer expects.
Yes, Illustrator shows those boundaries as Clipping entries. I would be happy if Illustrator could ask me during PDF opening if I'd like them to be shown or hidden. Jus didn't find it yet. -
3. Re: One question about Form XObject and Illustrator View Outline mode
(Leonard_Rosenthol) Nov 6, 2008 10:44 PM (in response to andrejusc)You would need to actually clip/crop the vector lines to the bounding box of the XObject. -
4. Re: One question about Form XObject and Illustrator View Outline mode
andrejusc Nov 6, 2008 10:52 PM (in response to andrejusc)Could you elaborate a little bit more about that clip/crop? What PDF codes I need for that from PDF Reference? -
5. Re: One question about Form XObject and Illustrator View Outline mode
(Leonard_Rosenthol) Nov 7, 2008 11:01 AM (in response to andrejusc)It's not as simple as just adding operators - it would involve actually changing your content to not have any objects extend beyond the bounding box. -
6. Re: One question about Form XObject and Illustrator View Outline mode
andrejusc Nov 7, 2008 11:37 AM (in response to andrejusc)I don't have any path objects which extend beyond the bounding box of Form XObject. Do I still need to change it (any of those paths) then?
