4 Replies Latest reply on Nov 7, 2008 2:51 PM by CrazyMerlin
    Dead debugger...or just AIR?
    CrazyMerlin Level 1
      Kind of a 2 sided deal this.
      Since starting to do AIR apps my debugger fails, but is it just because it is AIR?
      The thing is, I started an AIR app, then it got complex and so I now need some debugging. Is there a way to switch this back to just Flex so I can debug, or will I need to create a new project and import my code?
      The error I get when trying to run the debugger is this:
      quote:
      Process terminated without establishing connection to debugger.
      Command:
      "C:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\bin\adl.exe" C:\Dev\FlexAIR\SiteInfo\bin-debug\SiteInfo-app.xml C:\Dev\FlexAIR\SiteInfo\bin-debug
      Output from command:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at SiteInfo/selectAllSitesResult()[C:\Dev\FlexAIR\SiteInfo\src\ClientInfo.as:222]
      The TypeError is irrelevant ( or is it? ) as the code I need to debug doesn't go that far.
      Yes, you guessed, I'm new to Flex...PHP developer :)
        • 1. Re: Dead debugger...or just AIR?
          Level 7
          "CrazyMerlin" <webforumsuser@macromedia.com> wrote in message
          news:geuccl$phv$1@forums.macromedia.com...
          > is
          > AIR?
          > some
          > or
          > Command:
          > object
          > reference.
          > at
          > doesn't
          > go that far.
          Try opening the Task Manager and seeing if there are any open instances of
          adl.exe running. If there are, terminate them.
          HTH;
          Amy
          • 2. Re: Dead debugger...or just AIR?
            Jed Schneider
            Installing flash 10, seemed to be the end of my debugger. Have you installed 10 on your machine?
            • 3. Re: Dead debugger...or just AIR?
              Zanzibar96
              Flash player 10 totally killed my debugger in FlexBuilder.
              After a bit of research I just shut all programs down and did the uninstall of FP 10 plus uninstall of FP 10 active X and did a install of FP9 and FP 9 debugger and it has been working smoothly since.
              • 4. Re: Dead debugger...or just AIR?
                CrazyMerlin Level 1
                quote:
                Yes I did when I installed FlashCS4....time to kill it then!
