Expand my Community achievements bar.
How to..
Avatar
Level 1
Hi I'm new to flex and still trying to figure out what is
what
I've got this in my main flex file
<mx:RemoteObject id="roleTitle" destination="ColdFusion"
source="Roletitle_example.CF.RoleTitle" showBusyCursor="true" />
<mx:Panel width="50%" height="100%" layout="vertical"
title="Role titles" id="panel1">
<mx:DataGrid width="100%" height="90%"
dataProvider="{roleTitle.getAll.result}"
id="dgItem" >
<mx:columns>
<mx:DataGridColumn headerText="Role title"
dataField="sJobTitleName" />
<mx:DataGridColumn headerText="Code" dataField="sJobcode"
<mx:DataGridColumn headerText="Disipline"
dataField="sIndustryName" />
</mx:columns>
</mx:DataGrid>
</mx:Panel>
<mx:Button id="pbGridLoadSearch" label="Load"
click="roleTitle.getAll();" />
but I keap getting this error and I don't know what it means.
[RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Security.Error error Error #2048: Security
sandbox violation:
file:///C|/Inetpub/wwwroot/Roletitle%5Fexample/main.swf may not
load data from
http://localhost/flex2gateway/."
at mx.rpc::AbstractInvoker/
http://www.adobe.com/2006/flex/mx/internal::faultHandler()
at mx.rpc::Responder/fault()
at mx.rpc::AsyncRequest/fault()
at mx.messaging::ChannelSet/::faultPendingSends()
at mx.messaging::ChannelSet/channelFaultHandler()
at flash.events::EventDispatcher/dispatchEvent()
at
mx.messaging.channels::NetConnectionChannel/::defaultErrorHandler()
at
mx.messaging.channels::NetConnectionChannel/::securityErrorHandler()
Avatar
Level 1
This is a security error. I guess you'll need to trust the
location. Rightclick on any opened swf. Goto settings- >Advanced
-> Global Security Settings Panel and add the location there to
trust it.
Avatar
Level 1
ok is there anotehr wa to see that the data is getting to the
flash file
My page loads up and says getting data from localhost... but
no data is being displayed in my grid
Cheers
Avatar
Level 1
Are you running your swf from a C: drive based path or web
based path (
http://localhost....). I would
suggest that you load main.swf from the web based path.
There are some security restrictions which do not allow a swf
to access data from a domain different from the location of the
swf. Also if the swf needs any data file, please keep the file in
the same directory as the swf.
You can debug data loading by adding the following to the
mx:RemoteObject declaration.
fault="Alert.show(event.fault.faultstring), 'Error'"
result="Alert.show(event.result), 'Result' "
Anjali Bhardwaj
Flex SDK Development Team
