3 Replies Latest reply: May 5, 2008 11:23 PM by (Aandi_Inston) RSS
    Where could I find AdobePDFL.lib file?
    andrejusc Community Member
      I've downloaded Adobe Acrobat SDK 8 (file SDK8_v2_Full_win.zip), but don't see mentioned in plug-ins development guide AdobePDFL.lib inside that zip. Should I run some additional setup for it to be extracted?
        • 1. Re: Where could I find AdobePDFL.lib file?
          (Aandi_Inston) Community Member
          The document is incorrect to state that the PDF Library is shipped
          with the SDK. The PDF Library must be separately licensed, usually
          from DataLogics.
          Aandi Inston
          • 2. Re: Where could I find AdobePDFL.lib file?
            Hi Aandi,
            Thank you for quick reply. Could you tell me if I need that PDF Library if I want to compile plug-in? Or Acrobat SDK by itself (i.e. without PDF Library API/SDK) is enough for that? What I need from plug-in is ability to shift particular PDF file page by specific margin right/left for later book printing.
            • 3. Re: Where could I find AdobePDFL.lib file?
              No, not at all. This is a separate product that lets you write
              applications that don't need Acrobat.
              Well, the SDK by itself doesn't do anything, it's just documentation,
              samples, header files. I just want to emphasise that if you write a
              plug-in, it has to be loaded into Acrobat where it will be run, for
              example, when a menu item is used (the plug-in chooses that). You will
              not be able to use the free Reader as a substitute for Acrobat.
              Aandi Inston
