12 Replies Latest reply on Nov 5, 2008 11:48 AM by Lea84
    File display Problem
    Lea84
      Hi having trouble uploading my web site for the first time.
      I have uploaded through dreamweaver CS3 and the files seem to be on my web site when I go to it but in file format. Plus my html scripts are not displaying on the page. Any Ideas as to where I went wrong?
      Please respond have been trying get an answer for ages and cant seem to find one!
        • 1. Re: File display Problem
          Level 7
          For starters how about a link to the site...
          Walt
          "Lea84" <webforumsuser@macromedia.com> wrote in message
          news:ge3cdb$raj$1@forums.macromedia.com...
          > find
          > one!
          • 2. Re: File display Problem
            Lea84 Level 1
            www.mygamingmate.com
            • 3. Re: File display Problem
              Level 7
              What is the name of your "Home" page file?
              news:ge3qfu$f39$1@forums.macromedia.com...
              • 4. Re: File display Problem
                Level 7
                Lea84 posted in macromedia.dreamweaver:
                Rename this: My gaming mate simple design.html
                to this: index.html
                Then clean up the 480 some odd errors before expecting the JavaScript
                to work. For instance, it seems mighty strange to have JavaScript
                inside the <noscript> element.
                Mark A. Boyd
                Keep-On-Learnin' :)
                • 5. Re: File display Problem
                  Level 7
                  Mark A. Boyd posted in macromedia.dreamweaver:
                  > to this: index.html
                  No? OK, I see you've uploaded more files.
                  Now rename this Home page.html to index.html
                  You still have errors to contend with.
                  Also, I recommend avoiding file names with spaces in them. You could
                  use underscore or dash to separate the words, something like:
                  be-aware.html instead of Be Aware.html
                  And, wow, 160 characters for a jpeg file name? Just curious, but why?
                  Mark A. Boyd
                  Keep-On-Learnin' :)
                  • 6. Re: File display Problem
                    Lea84 Level 1
                    Thank You for the suggestion I will try them!
                    I just saved the jpegs from the web and didn't think to change the name, would this make a difference?
                    • 7. Re: File display Problem
                      Level 7
                      It won't make a difference to how they're displayed.
                      It might make a difference to the copyright owners - if you haven't
                      obtained permission to use them.
                      Mark A. Boyd
                      Keep-On-Learnin' :)
                      • 8. Re: File display Problem
                        Lea84 Level 1
                        Hi, Still having trouble with the Java Scripts. I was putting them in through the non script because the script button doesn't work, it wont display anything. But if I use the non script it displays until I upload it? I did Validate it!
                        Thank You for your help!
                        • 9. Re: File display Problem
                          Lea84 Level 1
                          So your saying ony rename the homepage as index.html?
                          • 10. Re: File display Problem
                            Level 7
                            Whichever page you want to appear automatically when a visitor goes to
                            directly to www.mygamingmate.com should be named index.html. There's a
                            slight chance that it may need to be named default.htm, but since
                            you're using an Apache server, I bet it's index.html.
                            Mark A. Boyd
                            Keep-On-Learnin' :)
                            • 11. Re: File display Problem
                              Level 7
                              (I'm looking at Home page.html)
                              The w3c validator shows 69 errors:
                              http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.mygamingma
                              te.com%2FHome%2520page.html
                              Some of that should be fixed by changing line 2 in your code from
                              <html xmlns=" http://www.w3.org/1999/xhtml"><style type="text/css">
                              to
                              The only reference to JavaScript I see on that page doesn't actually
                              have any JavaScript to execute. You've simply wrapped a link in JS
                              script/noscript sections. Change this:
                              <td width="18%" height="205" scope="row"><script
                              type="text/javascript">
                              <a style="text-decoration: none;" href=" http://banner.32vegas.com/cgi-
                              bin/redir.cgi?member=Deeanne&profile=32v320da03&lang=da" ><img
                              src=" http://banner.32vegas.com/cgi-
                              bin/banner.cgi?member=Deeanne&profile=32v320da03" width=100 alt= ""
                              border="0"></a>
                              </script><noscript>
                              <div align="center"><a style="text-decoration: none;"
                              bin/redir.cgi?member=Deeanne&profile=32v320da03&lang=da" > <img
                              border="0"></a> </div>
                              </noscript></td>
                              to:
                              bin/banner.cgi?member=Deeanne&profile=32v320da03" width="100" alt= ""
                              border="0"></a>
                              </td>
                              (Note the quotes I added to the width parameter).
                              This is the basic structure for using inline JavaScript.
                              (Actual JavaScript code goes here)
                              </script>
                              <noscript>
                              (put what you want people to see here if they
                              don't have a JavaScript enabled browser)
                              </noscript>
                              That should help get you started.
                              Mark A. Boyd
                              Keep-On-Learnin' :)
                              • 12. Re: File display Problem
                                Lea84 Level 1
                                Hi so I figured out the problem with the Java scripts, it was a tag problem because they are external codes.
                                <script src="xxx.js"> instead of <script type="text/javascript">
                                But now my changes wont display only the old files. How do I fix this?
                                Thank You for your help! I couldn't have gotton this far without you!!!
