I bought and installed one copy of Acrobat 9, for the most part it is great but it has one flaw that means it is not useable for us. The dimension tool that was in version 7 is the most used tool for us. As 8 did not have it, and 9 appears not to have it we are going to stick with version 7.
The measuring tool is ok, but it takes 3-4 times as long to stick in a 2d dimension which is just too long when you are doing 100's of changes/day.
If someone knows a work around, plug in, or version update I have not found please let me know!.
Wish I had an answer for you, but I'm just dealing with it. Can't believe Adobe hasn't addressed this yet.
Brock N. Ervin
Environmental Scientist
Crawfordsville District, Planning Section
Indiana Department of Transportation
765-361-5259
I received an automatic update notification for Acrobat 9 Pro. It fixes the problem with the scale ratio!!!!! It no longer clears the manually input scale ratio every time you change tools or hit escape.
Brock N. Ervin
765-361-5259
Why has Adobe ignored such a measure issue? I just started using Pro 9 a few days ago and I'm already very frusterated with this issue, and I'm frustrated that I (we) have this bug to look forward to on every future project. Adobe needs to offer an update to fix this. The work arounds I've seen look just as complicated and don't permanently fix the problem.
