1 Reply Latest reply on May 17, 2006 11:07 AM by Rothrock
    Problem sorting an multidimensional array
    Level 7
      Problem sorting an array.
      Flash 7, As2
      I have this array with 3 elements. For each element I have 3 fields [name;
      win; loose]
      I would like to sort the array by field win.
      But when win is equal for more then one element what I would like to do is
      maintain the win order and add the loose order.
      Here's an example:
      // Declare the array
      var myArray:Array = new Array ();
      // Push the elements
      myArray.push ({ name:"Regina", win:10, loose:800 });
      myArray.push ({ name:"Ana", win:30, loose:500 });
      myArray.push ({ name:"John", win:10, loose:100 });
      // Sort by loose
      // Outputs John / Ana / Regina /
      myArray.sortOn ("loose");
      trace (myArray[0].name + " / " + myArray[1].name + " / " +
      myArray[2].name + " / ");
      // Sort by win
      // Outputs Ana / Regina / John /
      myArray.sortOn ("win", Array.DESCENDING | Array.NUMERIC);
      What I would like is to have on the final sort is:
      // Ana / John / Regina
      // win loose loose
      Does anyone have any idea in how to achieve this?
        • 1. Re: Problem sorting an multidimensional array
          Rothrock Level 5
          You have to make your own sorting function. I have a similar one at home but can't remember the syntax exactly off the top o-me-head. So read the help entry for Array.sort() and it will show you how to create your own sort function.
          I found mine to be a bit slow and it sped things up a lot if I did a primary sort using sortOn and then called sort(myfunction).
