1 Reply Latest reply on Oct 28, 2008 7:41 AM by Eva-KCI
    Numbered List Alignment
    Eva-KCI Level 1
      RH 5, HTML.
      I am using a numbered list (based on default css) and it appears to be perfectly aligned from WYSIWYG, but when I view the topic by clicking View Select Item (eyeglass icon) the list is not aligned appropriately - some numbers are indented more than others.
      Usually when things like this happen, which I cannot explain, I right click on the line where the text is and usually there are "span attributes" that I can remove to correct the issue, but there are no attributes for the list.
      This particular list is embedded within a chart (all step-by-step instructions are in a single column, but listed in multiple rows/cells), but I've also encountered the same issue when working with a number list outside of a chart.
      Does anyone know why this is happening & what I can do to correct it?
      Eva
        • 1. Re: Numbered List Alignment
          Eva-KCI Level 1
          I found the solution, but not the cause for the issue by looking over the TrueCode (compared aligned items to those that were not aligned).
          Code for aligned list was : style="list-style: decimal;"
          Code for unaligned list was: style="list-style: inside decimal:"
          I removed the word "inside" to straighten things out.
