This content has been marked as final.
Show 2 replies
1. Re: CFGrid Errors
Newsgroup_User Oct 28, 2008 9:52 PM (in response to kodemonki)if the grid shows up then it is NOT a problem with CFIDE not being
mapped. it sounds to me like maybe a cfc the grid binds to has an error...
first things first:
enable ajax debugging in cf admin and add ?cfdebug to the url of the
page with the grid (or &cfdebug if you already have other vars in the url)
this will show an ajax debugger, which can tell you what the problem is
or at least will point to where to look for the problem.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/ -
2. Re: CFGrid Errors
kodemonki Oct 29, 2008 8:49 AM (in response to kodemonki)If I have the EXACT same code in two places, one inside INTERNAL, one in ROOT, and one binds, shouldn't the other bind?
Also, I used CFDEBUG and it just says there's an uncaught error on 799. If I do a view source the file has less than 450 lines, the source file has 160 lines. Where is this number coming from?
My grid:
<cfform name="test">
<cfgrid name="dealer_grid" format="html" bind="cfc:data.get_dealers({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdi rection})" striperows="true" striperowcolor="gray">
<cfgridcolumn name="pa_code" header="P&A Code"/>
<cfgridcolumn name="dealership_name" header="Dealership Name"/>
<cfgridcolumn name="pending" header="Pending"/>
<cfgridcolumn name="immediate" header="Immediate"/>
<cfgridcolumn name="strategy" header="Strategy"/>
<cfgridcolumn name="status" header="Status"/>
</cfgrid>
</cfform>
data.cfc:
<cfcomponent displayname="data.cfc" output="false">
<cffunction name="get_dealers" access="remote" output="no">
<cfargument name="page" default="">
<cfargument name="pageSize" default="">
<cfargument name="gridsortcolumn" default="">
<cfargument name="gridsortdirection" default="">
<cfquery name="get_dealers" datasource="admi-prod">
SELECT dm.pa_code, dm.dealership_name, dm.dealer_id, fd.fad_employee_id, fe.lastname,
nvl(to_char(fd.pending_return_month), 'N/A') pending_return_month,
nvl(to_char(fd.immediate_return_month), 'N/A') immediate_return_month,
decode(strategy, 1, 'Aggressive', 2, 'Moderate', 3, 'Conservative', 'N/A') strategy,
fd.status
FROM dealer_master dm, fad_dealers fd, fad_employees fe
WHERE fd.dealer_id = dm.dealer_id
AND fe.fad_employee_id(+) = fd.fad_employee_id
AND dm.primary_manufacturer_id = 1
AND dm.termination_date IS NULL
AND fd.fad_employee_id = fe.fad_employee_id
AND fe.user_id = 52663
</cfquery>
<cfreturn queryConvertForGrid(get_dealers, page, pageSize)>
</cffunction>
</cfcomponent>
