9 Replies Latest reply on May 5, 2011 7:45 AM by Robbygjr
    Can't convert web page to PDF in IE
    Newcomer
      Hi, I was using Window XP with Adobe Acrobat Pro 8. It's running pretty well. I just got a new PC with Window Vista Enterprise. When I installed the Adobe, I got problem asking for "AdobePDF.dll". Yes, I did hotfix #930627 and updated Adobe to 8.1.1 but there is still error. I can't convert the webpage to PDF in IE. I checked the plug-in in IE, all the PDF plug-ins are enabled. But if I clicked on the Adobe tool bar in IE, none of the menus responses. Same thing happens to the popup PDF menu.
      Can anybody help me out?
      Thanks.
        • 1. Re: Can't convert web page to PDF in IE
          (Aandi_Inston) Newcomer
          If you are not using Adobe's "Create PDF Online" web site, perhaps you
          need the Acrobat Windows forum.
          Aandi Inston
          • 2. Re: Can't convert web page to PDF in IE
            Newcomer
            I have the same problem. Windows xp, new Adobe CS3 Web premium with Adobe Acrobat Pro 8.1.1 installed. all updates etc. From IE 7 the little Adobe menu choices do nothing.
            Same problem applies to if I select TEXT on a web page and right mouse click to be able to convert the TEXT or links to PDF do nothing.
            I have tried the repair install, and I also did a complete uninstall of Adobe Acrobat, and then re-installed... no help.
            Hope someone has a solution... I have tried so many things, and still it just does not work.
            Thanks ~ aj
            • 3. Re: Can't convert web page to PDF in IE
              Allan, if you have the same problem, I have the same reply. If you are
              Aandi Inston
              • 4. Re: Can't convert web page to PDF in IE
                Newcomer
                had a whole raft of problems setting up Adobe Arcobat and it will not print and never will if you try using the Print option Adobe printer.
                Problem solved!!!! Yahoooooooo, but need to do the following ......
                http://kb.adobe.com/selfservice/viewContent.do?externalId=329345
                This will allow the PDF Maker Icon to be dislayed on the Web browser IE 6 & 7.
                If your having problems with all the other MS office applications then you will have to do the following
                http://www.microsoft.com/downloads/details.aspx?FamilyID=4d951911-3e7e-4ae6-b059-a2e79ed87 041&DisplayLang=en
                2007 Microsoft Office Add-in: Microsoft Save as PDF or XPS
                MS have obviously had a problem and the fix is available at the above link
                Validation is required before you can download the file --------
                SaveAsPDFandXPS.exe
                Run the application.....
                After that all MS Office 2007 applications have an extra tab added to the header called Acrobat with option
                Create PDF
                Preferences
                Create and Attach to Email
                Create and Send for Review
                Start Meeting
                I did try to install the file you suggested
                http://support.microsoft.com/kb/930627 but that didn't work So must be a combination of Windows XP 64bit and Office 2007
                Well this has been a learning curve and may be of help to others.
                • 5. Re: Can't convert web page to PDF in IE
                  Newcomer
                  wont you find the solution, me also facing the same problem help me , PM me
                  • 6. Re: Can't convert web page to PDF in IE
                    Newcomer
                    copy the above link into a web page has the following information, so try one or all of the following. Its usually a config problem and the adobe support people were not very helpful in finding the answer, but hopefully the following will resolve the issue
                    PDFMaker icons are missing in Internet Explorer (Acrobat 6 and 7 on Windows)
                    Issue
                    The PDFMaker icons are missing in Internet Explorer.
                    Detail
                    You are using Acrobat 6 or 7 on Windows.
                    Solutions
                    Do one or more of the following solutions:
                    Solution 1: Unlock the Internet Explorer toolbar.
                    To determine if the toolbar is locked and unlock it if necessary:
                    1. Open Internet Explorer.
                    2. Choose View > Toolbars:
                    -- If the Lock The Toolbars option is selected, then click Lock The Toolbars to clear the check mark.
                    -- If the Lock The Toolbars option is not selected, then the toolbars are already unlocked.
                    3. Close Internet Explorer and then re-open it.
                    Solution 2: Set Internet Properties to enable third-party browser extensions.
                    1. Close Internet Explorer.
                    2. Open Acrobat and choose Edit > Preferences.
                    3. Choose Internet from the list of categories on the left, and then click the Internet Settings button.
                    4. In the Internet Settings window, click the Advanced tab.
                    5. Under the Browsing section, select "Enable third-party browser extension (requires restart)" and Click OK.
                    6. Start Internet Explorer.
                    Solution 3: Do a repair of Acrobat.
                    1. Start Acrobat.
                    2. Choose Help > Detect And Repair.
                    3. When the repair process is complete, restart your computer.
                    Solution 4: Make sure PDFMaker for Internet Explorer is installed properly.
                    1. Choose Start > Settings > Control Panel and double-click Add/Remove Programs (Windows 2000), or choose Start > Control Panel and double-click Add Or Remove Programs (Windows XP).
                    2. Click Adobe Acrobat [version] and choose Change. You will enter the Acrobat Setup.
                    3. Choose Modify from the Setup dialog box.
                    4. Expand Create Adobe PDF.
                    5. Click the Acrobat PDFMaker menu and choose "This feature, and all it's subfeatures, will be installed on local hard drive."
                    6. Click Next, and then click Update.
                    Solution 5: Disable Firewall, Antivirus, or Internet Blocker software.
                    Certain protection programs prevent plug-ins from loading in Internet Explorer. Disable any such software and restart Internet Explorer.
                    Original VersionsAcrobat Professional 6.0Acrobat Professional 7.0Acrobat Standard 6.0Acrobat Standard 7.0
                    TechNote DetailsLast Update: 01-04-2007
                    OS: Windows
                    Permanent Link: http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=329345
                    Products Affected:
                    • 7. Re: Can't convert web page to PDF in IE
                      Newcomer
                      Thanks for link
                      Good Luck.
                      ______
                      My Si tes
                      • 8. Re: Can't convert web page to PDF in IE
                        Philbiker Newcomer
                        I am having this same problem.  Running Windows XP, our helpdesk just installed IE7 last week, and that has seemed to break the PDF conversion Add-ons for IE.  Running Acrobat Pro 8.1.3 and Dreamweaver CS3 9.0 Build 3481.  Under IE6 the export worked perfectly, under IT7 no go.  Any help with this would be appreciated!!!
                        • 9. Re: Can't convert web page to PDF in IE
                          Robbygjr Newcomer
                          I have Acrobat 9 Pro, IE 8 and Vista Home Premium (64 bit). Prior to recent MS updates, I had been able to convert web pages. After reading several of the fixes in this forum, I checked Tool bars, they were unlocked,. I then checked Ie's Internet Properties for third party extensions. It was not checked. I checked the box, closed IE, re-opened it and converted a webpage to PDF.
