This content has been marked as final.
Show 3 replies
1. Re: 5.1 mixing
(Eric_Snodgrass) Nov 21, 2008 9:41 PM (in response to therayman)I don't know. Did you ask in the Premier forum? -
2. Re: 5.1 mixing
therayman Nov 22, 2008 11:10 AM (in response to therayman)I should clarify that the reference is to Audition's Surround encoder mixing and has nothing to do with Premier. -
3. Re: 5.1 mixing
MusicConductor Nov 30, 2008 7:53 PM (in response to therayman)Ray, in that case, it sounds as though you need to give the channels panning positioning in the surround panner. When you first open it, the surround panner has a center-dot-position for each track in which you've placed audio. You'll need to click through each one and put it where it belongs. Do this with care -- relative levels can change depending on what you select (for example, assigning to one of the channels in mono).
If you've already done that, then it may be an issue with how your sound card is set up for previewing. You'll want to look at Edit>Audio Hardware Setup and click the surround encoder tab to make sure that each of the six channels is being previewed through the correct speakers.
