11 Replies Latest reply on May 24, 2016 8:27 PM by Bob Howes
    Opening M4A Files
      I notice Audition won't open M4A files. Is there a plugin that can be downloaded to make this happen?
      I suppose I could copy my M4A's to CD and open them that way.... as long as during the copy process no loss of quality happens to the files. Kind of a pain to copy them all to disc and open them as track 1, track 2. etc., instead of the original name of the files.
        • 1. Re: Opening M4A Files
          Stan Oliver Level 1
          Try the Apple Quicktime Filter at http://www.vuplayer.com/audition.php.
          • 2. Re: Opening M4A Files
            Level 1
            I can't get anything to go in the Audition folder from WinRAR. Heaven help us if the program actually just let you copy and paste it in, that would be too easy. When I tried to go back and unpack it to the Audition main folder (I am assuming that's where it's supposed to go. The instructions said program folder), it said I don't have permission. It's silly when things are made this difficult. It makes me wonder if it will work once I do get them in the right place. Can you provide a simple solution to get these files where they need to be, and express what folder they actually need to be in?
            Thanks, I appreciate your help.
            • 3. Re: Opening M4A Files
              Level 1
              I got it to work. I downloaded WinZip and it handled the chore. It's not an ARTARD program like WinRAR and will actually do what it's supposed to.
              I put the qt filter in the main folder and it worked, Audition opens M4A files now. It's interesting, the info they put in the M4A files will not allow you to preview the songs in Audition but WILL let you open them up lol. Another thing that is interesting is Adobe is telling me the songs are at different bit rates than what iTunes are claiming. At iTunes you pretty much get everything at 256 (sometimes 128). However, Audition is saying some songs are at 258, 261, 252, etc.
              • 4. Re: Opening M4A Files
                HomeboyStudio Level 1
                This could be a problem with WinRar. The downloaded file is actually a ZIP file. Windoze XP supports opening ZIP files natively.
                If you right-click on the downloaded ZIP file and choose "Explore" then this native ZIP access kicks in and you will see the two files "qt.flt" and "qfilter.txt". You should be able to highlight and copy these to sysdrive:\Program Files\Adobe\Audition 3.0 folder.
                --Dean
                • 5. Re: Opening M4A Files
                  sweeppicker Level 1
                  I was going through the same problem. Thanks for sharing and helping out.
                  Cheers,
                  Adam@pheromones.com
                  • 6. Re: Opening M4A Files
                    voiceboy1 Level 1
                    Fantastic!
                    Thank you for this. I had to update Quicktime & reboot first & then it worked brilliantly!
                    Al
                    • 7. Re: Opening M4A Files
                      chatniran
                      If you to open and edit your .m4a format file on adobe audition take this step.
                      1. Open your Adobe audition.
                      2. Go to Edit menu.
                      3. Go to Preferences.
                      4. Click-on Media & Disk cache
                      5. And click Enable DLMS Format support.
                      Now you can open and edit your m4a format file.
                      • 8. Re: Opening M4A Files
                        ryclark Level 6
                        This is a five year old topic when the instructions you give wouldn't work with Audition at that stage of it's development at AA v.3. DLMS support only came in recent versions of Audition from about CS6 onward.
                        • 9. Re: Opening M4A Files
                          Chris @ LGC
                          Thanks for the link, I have installed the filter on both Audition 1.5 and Audition CC (2104) successfully
                          • 10. Re: Opening M4A Files
                            LeyendaV Level 1
                            Won't work for me
                            • 11. Re: Opening M4A Files
                              Bob Howes Adobe Community Professional & MVP
                              Note that this is a 7 year old topic and the answer applies to a very old version of Audition.  Since the time this thread was created, there have been many changes to the way Audition handles video.
                              In order to answer you, we'll need to know more details of you system, the version of Audition you're using and details of the video you're trying to open.
                              You could tag it on here if you really want to but I'd suggest you start your own topic instead to avoid confusion.
