4 Replies Latest reply on Jan 27, 2009 11:00 AM by SteveG(AudioMasters)
    Help!  Saving causes successive loss of quality and volume.
      In Adobe Audition 3.0 (used with Vista):
      Every time I save or export to save, the file comes back at significantly decreased volume that it had before (visible in the sine wave height, as well as audibly). When burned, the more times a file was saved, the worse it sounds. If I need to do three or four cuts within a piece of music and I save after performing each cut, by the time I'm finished, the burned CD sounds like the musician is at the bottom of a well and has an old tape-recorder "drag" effect to the sound.
      Please help, if you have any suggestions.
      Thank You!
