Hello there,
Recently I updated Auto Tune to the latest Version 4.3 DirX. Although there were no problems with other Audio Editors on my computer, after I refreshed the effects loop in Audition 1.5, Auto Tune was shown as unsupported. I searched the Adobe data base and could see others have had this problem, but I have been using Auto Tune for quite a while, and this was the first sign of a problem. One of the posts had found a solution by editing the Registry, (which proved to be correct). However, I decided to email Antares first. Antares replied quickly with the solution,(which worked), and explained that the problem occurred with the change from Cool Edit 2 to Adobe Audition, and that the problem is specific to Audition. So, here is what to do if you are affected by this......
This fix should only be attempted if you are comfortable working with the Windows Registry.
(1) Close Adobe Audition.
(2) Open the Registry by going to the Start Menu, selecting Run, then typing regedit, and clicking OK.
(3) Under HKEY_LOCAL_MACHINE, go to the key
\SOFTWARE\Adobe\Audition\Plugin\DirectX\
(4) Locate the Data Item whose Name is (02A06B08-744E-40E3-8B78-E45D71750DC8)
(5) Delete that item.
(6) Close the Registry.
(7) Run Adobe Audition.
(8) In the Edit View, Refresh the effects List.
All should now be well.
Here is a link to this information at Antares....
http://portal.knowledgebase.net/al/5384/7553/article.asp?aid=138147&n=1&tab=search&bt=4&r= 0.3019785&s=
And here is a link for furher help at Antares.....
Brian English
brian@antarestech.com
831-461-7800x233
http://www.antarestech.com
Product Specialist
Antares Audio Technologies
231 Technology Circle
Scotts Valley CA 95066
All the Best,
aomahana.
www.audioarts.co.nz
