4 Replies Latest reply on Oct 28, 2008 2:03 PM by bezly
    send XML data for credit card processing
    bezly
      I’m trying to implement submission of an XML document from my website for credit card processing using my merchant’s API.
      Here’s the format I’m using for my request. For some reason I keep getting an error message telling me “Invalid Request Format. XML request is not well-formed or request is incomplete.”
      I know the XML itself is correct, as I can submit it directly through the URL string in the browser and it works OK.
      Here’s what I’m doing:
      <cfsavecontent variable="strXML">
      <!--- NOTE: test data below -- not my real data --->
      <txn>
      <ssl_merchant_ID>123456</ssl_merchant_ID>
      <ssl_user_id>123456</ssl_user_id>
      <ssl_pin>V6NJ3A</ssl_pin>
      <ssl_transaction_type>ccsale</ssl_transaction_type>
      <ssl_card_number>1111111111111111</ssl_card_number>
      <ssl_exp_date>1210</ssl_exp_date>
      <ssl_amount>2.34</ssl_amount>
      <ssl_salestax>0.00</ssl_salestax>
      <ssl_cvv2cvc2_indicator>1</ssl_cvv2cvc2_indicator>
      <ssl_cvv2cvc2>321</ssl_cvv2cvc2>
      <ssl_invoice_number>1234</ssl_invoice_number>
      <ssl_customer_code>1111</ssl_customer_code>
      <ssl_first_name>customer</ssl_first_name>
      <ssl_last_name>name</ssl_last_name>
      <ssl_avs_address>1234 main st.</ssl_avs_address>
      <ssl_address2>apt b</ssl_address2>
      <ssl_city>any town</ssl_city>
      <ssl_state>ST</ssl_state>
      <ssl_avs_zip>55555</ssl_avs_zip>
      <ssl_phone>555-555-5555</ssl_phone>
      <ssl_email>customer@email.com</ssl_email>
      </txn>
      </cfsavecontent>
      <cfhttp url="https://www.myvirtualmerchant.com/VirtualMerchant/processxml.do?xmldata=" method="post">
      <cfhttpparam type="XML" value="trim(strXML)">
      </cfhttp>
      <cfoutput>#cfhttp.FileContent#</cfoutput>
      Can someone tell me what I’m doing wrong?
      (The developer guide is available here:
      https://www.myvirtualmerchant.com/VirtualMerchant/download/developerGuide.pdf)
      thanks!
        • 1. Re: send XML data for credit card processing
          Level 7
          <txn>
          Some xml parsers can be very sensitive to any extra anything, even white
          space, preceding the xml root tag.
          You may want to try this.
          <cfsavecontent variable="strXML"><txn>
          </cfsavecontent>
          • 2. Re: send XML data for credit card processing
            bezly Level 1
            I tried it -- thanks, but no luck. Doesn't the Trim() around the string take care of that though?
            -B
            • 3. Re: send XML data for credit card processing
              Level 7
              Looking deeper into your original post.
              You say this...
              "I know the XML itself is correct, as I can submit it directly through
              the URL string in the browser and it works OK."
              That would say to me you are using get URL parameters not post form
              parameters. Also you don't put the name of the url parameter in the url
              string, unless you put the value there. If you use the
              <cfhttpparam....> tag, it should contain the name. Finally you seem to
              be missing some pound signs.
              Give this, or something like it, a try.
              <cfhttp
              method="get">
              <cfhttpparam type="url" name="xmldata" value="#trim(strXML)#">
              </cfhttp>
              • 4. send XML data for credit card processing
                bezly Level 1
                Thanks! You rock! I was pulling my hair out.
                The trick ended up being using the name within the cfhttpparam as you suggested.
                Everything else it handles OK either way. (get/post)
                -B
