1. Re: Output to PDF module not working - Bridge CS4
(Richard_N_Davis) Jan 17, 2009 5:59 PM (in response to mikeklar)I have the same problem, but no solution. -
2. Re: Output to PDF module not working - Bridge CS4
mikeklar Jan 17, 2009 6:26 PM (in response to mikeklar)Richard
Glad to see I'm not the only one.
Having dealt with our friends (Adobe Support), who although willing to respond, have not been able to solve this issue. Now it appears I will not longer receive their kind (but not so helpful) suggestions unless I fork over more money to assist in debugging the product :-(
Since acquiring the Master Suite, there have been a number (5 in all) updates that simply won't install, and the Output Module is flaunted as a relatively important part of the collection for creating WEB sites.
Hopefully, there are others who have this issue and are willing to post here. It seems it may be the only way we are going to see something done about this.
Cheers,
Michael -
3. Re: Output to PDF module not working - Bridge CS4
mikeklar Jan 20, 2009 1:37 PM (in response to mikeklar)FWIW
Adobe Technical Support did respond and reopened the case issue regarding this plus some additional matters. They requested all install logs and subsequently advised work is being done to find a solution.
Hopefully, we will hear from them soon.
Cheers,
Michael -
4. Re: Output to PDF module not working - Bridge CS4
(Not_You) Mar 18, 2009 12:36 PM (in response to mikeklar)Any solution on this? It's now 2 months later and I'm getting the same message. -
5. Re: Output to PDF module not working - Bridge CS4
Matthew Laun Mar 25, 2009 1:15 PM (in response to mikeklar)I'm happy to say, we've finally found the root cause of the issue which has been causing CS4 updates that patch files (instead of replacing them) on some Windows machines. This issue, cause, and solution are documented here:
http://www.adobe.com/go/kb408524
Sincerely,
Matthew -
6. Re: Output to PDF module not working - Bridge CS4
mikeklar Apr 1, 2009 7:32 AM (in response to mikeklar)Thank you, I'll give that a try as soon as I get finished with my present project.
Cheers,
Michael -
7. Re: Output to PDF module not working - Bridge CS4
(Robert_Simons) Apr 2, 2009 6:55 PM (in response to mikeklar)The solution seems to only apply to Vista. Has a solution been found for Windows XP? -
8. Re: Output to PDF module not working - Bridge CS4
mikeklar Apr 8, 2009 6:39 PM (in response to Matthew Laun)Mathew
I've made the change to the application Data NTFS Juntion per the instructions, but have not yet un/reinstalled the entire Master Suite.
However, there is an improvement in that out of five updates that did not install previously only three failed to install this time.
These are the "Output Module 2.1", "InDesign CS4 6.0.1" and "Service Update".
Of interest; after the failed install of the Output Module, this time it did not cause the original version in Bridge to fail.
When I have more time I will un and reinstall the entire Master Suite.
Cheers
Michael
9. Re: Output to PDF module not working - Bridge CS4
Francois C Aug 11, 2009 3:48 PM (in response to mikeklar)I'm having a similar problem on OSX. Output module is just not displaying. Have been looking for answers for months now. It's not like you can even uninstall and re-install bridge all by its lonesome! I've tried the updates and more, no solutions forthcoming.
I've posted a screenshot here: http://creativebits.org/files/Picture-2.jpg
