3 Replies Latest reply on Oct 29, 2008 6:30 PM by Kronin555
    Application.cfc Form Validation
      Hi all. I posted this question on the site I got the example from, but they removed my question for whatever reason so I'll try here:
      Please click the link for the code: Click Here
      I tried this example, and it works, however a couple of things I'm trying to figure out:
      1. The validation errors change their order each time you re-submit, is there a way to control that?
      2. I tried populating the form elements with what was posted, but the form isn't posting anything, and I'm looking to see if anyone else has this problem
      Thanks.
        • 1. Re: Application.cfc Form Validation
          Dan Bracuk Level 5
          I didn't visit your page. The subject line suggests that you are trying to do form validation in an application.cfc file. Bad idea. Do it in another file somewhere.
          • 2. Re: Application.cfc Form Validation
            Level 1
            Hey.. Not sure what happened to my 2 points above. The preview looked fine before I submitted it. Weird!
            Anywho.....
            Thanks for your reply Dan.
            This (amongst other code) is what they put in there:
            <cffunction name="onError" returntype="void">
            <cfargument name="exception" required="true" />
            <cfargument name="eventName" type="String" required="true" />
            <cfif isDefined('exception.StackTrace') AND isDefined('exception.errors')
            AND exception.StackTrace contains 'coldfusion.filter.FormValidationException'>
            <cfset session.validationError = exception.errors />
            <cfset session.stFormData = duplicate( form ) />
            <cflocation url="#cgi.HTTP_REFERER#" addtoken="false" />
            <cfelse>
            <cfthrow object="#exception#" />
            </cfif>
            </cffunction>
            So,why would this be a bad idea?
            Oh, and if the above code makes it ok to add to Application.cfc, then my quesitons 1 and 2 were:
            1. The validation errors return in different orders every time the form is posted, and was wondering how to control this.
            2. I couldn't get the form to post any values.
            • 3. Re: Application.cfc Form Validation
              Kronin555 Level 1
              You can't. That's one of the downsides of using cfform validation.
              As to why your form didn't post any values, you're going to need to post your form code (from <cfform...> to </cfform>)
