3 Replies Latest reply on Oct 29, 2008 2:10 PM by fazstp
    Union method not working with 0 area rects?
    Applied CD Level 1
      I need a fast method for deriving the rect defined by two points. I’ve done this before using min/max comparisons for each side but I thought the following would be an incredibly simple one-liner to produce the same result, problem is it always returns rect(0,0,0,0). Is there a bug in the union method or am I overlooking something?
      pointA = some point
      pointB = some point
      myRect = rect(pointA.locH,pointA.locV,pointA.locH,pointA.locV).union(rect(pointB.locH,pointB.locV, pointB.locH,pointB.locV))
        • 1. Re: Union method not working with 0 area rects?
          Level 7
          > I?ve done this before using min/max comparisons for each side but I
          > pointA = some point
          > pointB = some point
          > myRect =
          > ntB.locV,pointB.locH,pointB.locV))
          Union: "returns the smallest rectangle that encloses the two *rectangles*
          rect1 and rect2."
          Go with your min/max method: it will take next-to-no-time. Assuming that
          what you need the rect for actually requires the rect to be "right-way-up".
          Andrew
          • 2. Re: Union method not working with 0 area rects?
            Applied CD Level 1
            Thanks Andrew, I did end up using a four line min/max solution, works fast enough.
            • 3. Re: Union method not working with 0 area rects?
              fazstp Level 2
              You could still make it one line;
              myRect = rect( [pointA[1], pointB[1]].min(), [pointA[2], pointB[2]].min(), [pointA[1], pointB[1]].max(), [pointA[2], pointB[2]].max() )
