1 Reply Latest reply on Oct 9, 2008 12:34 AM by happybrowndog
    DataGrid multiple editable columns error patch
    siki^2
      When having DataGrid with multiple editable columns the CollectionEvent UPDATE should be sent when then row is changed (DataGridEvent.ITEM_EDIT_END reason != DataGridEventReason.NEW_COLUMN) otherwise the disableAutoUpdate is called preventing the UPDATE event to be triggered..
      the problem is that once the row is changed
      the enableAutoUpdate is called (DataGrid.as:4814) causing the UPDATE CollectionEvent to be fired
      the currently edited value is commited (DataGrid.as:4857)
      another UPDATE event fired (DataGrid.as:4861)
      this patch forces the UPDATE event to be fired just once for the row after the last edited value has been commited.
