7 Replies Latest reply on Apr 27, 2007 8:21 AM by John_Cornicello_Photo
    ?? Info readings for white balance in Raw Bridge ??
      I'm running CS2 9.0.2 on a G5 iMac and I'm having an annoying but intermittent problem with the information palette shown in the top right hand corner of the Camera Raw window when you open Raws in Bridge. Often when I try to do a white balance, if I'm just trying to roll the pointer over the gray scale to get readings, the info numbers will flash quickly instead of maintaining and updating as you move the mouse.
      The values are not blown out or underexposed but you simply cannot read the values in the palette. You have to click on your medium gray, etc... before you can read the numbers on the palette.
      Is anyone else having this problem? Does anyone have any ideas on how to fix it?
      Thanks.
