3 Replies Latest reply on Aug 4, 2007 11:02 PM by jen0dorf
    cut and paste
    jen0dorf Level 1
      Hi
      just discovered the forum and have a couple of queries please.
      If I open a raw file via bridge and then crop it I seem unable to move on
      from there. Normally if I double click it then creates a new image using the
      cropped section. Does camera raw not do this?
      Second Can I start camera raw from within photoshop? it's shown as an addin
      but I seem unable to get it to open my raw files unless I use bridge
      thanks
      Ian
      i.edwards@NOSPAMedwards-micros.co.uk
      http://www.edwards-micros.co.uk
        • 1. Re: cut and paste
          Ramón G Castañeda Level 4
          Click here for advice on how to ask your question correctly for quicker answers. Thanks!
          • 2. Re: cut and paste
            JimHess-8IPblY Level 3
            Ian,
            All edits in ACR are nondestructive. You will always be able to see the entire image in ACR, including the part that you have cropped away. It is that way by design so that if, at a later time, you want to crop your image differently. When you return to Bridge the thumbnail should reflect the cropped image.
            Regarding your second question. Refer to your Bridge preferences. There is an option there to have ACR hosted by Bridge. Many people prefer this configuration. If you don't like it, make sure to remove the check mark from that option. But you can always open a raw file from Photoshop using the File/Open menu option.
            • 3. Re: cut and paste
              jen0dorf Level 1
              Hi Thanks for that, I now see the logic that camera raw opens raw files
              using the file open option
              cheers
              Ian
