6 Replies Latest reply on Dec 21, 2007 3:18 PM by mikeengles
    ACR vs Lightroom
    JimHess-8IPblY Level 3
      I'm sure this has been discussed extensively. But after reading the new version of the ACR book that Jeff Schewe so masterfully updated, I'm wondering what the real advantage is to also having Lightroom. I see Jeff answering comments in the Lightroom forum and discussing how he uses that program for different purposes. Apparently I'm getting Lightroom for Christmas, and I'm not really that excited about it. I understand the DAM features in Lightroom, but they don't excite me. I was just curious to know what others are thinking.
        • 1. Re: ACR vs Lightroom
          DavidRitch-BPYbxw
          The TAT (Targeted Adjustment Tools) in Lightroom are very cool. They allow you to select a tonal range and modify it by clicking on your image and dragging. I'd *love* to have that capability in ACR.
          I'm also not terribly impressed with its DAM capabilities, and can't use it's Print module. Unfortunately, the last time I looked at it (and I think that this is still the case), the Print module did not support printing to a file. Since I send my printing to a pro lab (it's cheaper and more consistent that I've been able to get with any of my own inkjets), I need to be able to print to a file.
          David
          • 2. Re: ACR vs Lightroom
            Jao vdL Adobe Community Professional & MVP
            David. Many ways of doing that.
            The easy way is to simply export to sRGB jpegs and send them to the lab. Will look good, but for using borders or logos or for better color quality consider the following:
            Not using the print module:
            The new very cool way using Lightroom/mogrify plugin
            Simple way (but many more steps) using LR and Photoshop
            Or using the print module:
            using borders and logos
            Using automator to create jpegs directly from the print module
            • 3. Re: ACR vs Lightroom
              I'm still working with the trial version of Lightroom. Last night I was working with an image that admittedly wasn't taken under the most ideal lighting conditions. I spent quite a bit of time in Lightroom working on the dynamic range to bring out shadow detail in some pine trees. I could never make the adjustments to my satisfaction. So I started over using Photoshop CS3 and ACR 4.3.1. In a matter of minutes I had the image looking the way I wanted it. The slider controls are more precise in ACR on my computer. But that might be the problem. I am on an older computer that just barely meets the requirements for some of this new software.
              • 4. Re: ACR vs Lightroom
                DavidRitch-BPYbxw Level 1
                Jao,
                Thanks for those pointers. The mogrify plugin looks particularly interesting.
                I see you use a Mac. Some of the procedures that you suggest are Mac-specific. On a Windows box, for resampling, colorspace transformation, and print sharpening, I like QImage pro. It sounds like the mogrify plugin may perform the same sort of functions that QImage does. I'd be interested to see a comparison between the results of resampling (and sharpening) with the two.
                However, for various reasons, I have recently switched to Linux as my primary working platform, so this is sort of academic from my perspective.
                Still, I think that it's unfortunate that we need workarounds such as this, when so many people print to something other than a locally attached printer.
                David
                • 5. Re: ACR vs Lightroom
                  I agree completely! The output module should have arbitrary icc profiles and output sharpening. It should also be possible to natively print to a jpeg file.
                  • 6. Re: ACR vs Lightroom
                    mikeengles Level 1
                    Hello
                    I had the same problem, needing a RAW decoder for my Canon 5D.
                    Lightroom and ACR were OK, but having also tried out Photoshop CS3 and Bridge I could not see the point of Lightroom. I think that eventually Lightroom and Bridge will be combined and be part of Photoshop. It happened to Imageready.
                    Mike Engles
