5 Replies Latest reply on Mar 20, 2008 8:26 AM by (Peter_J_Cox)
    camera raw/white blance
      I am using windows and PS3.
      I am using a infrared converted Nikon D70, image capture must be done in raw only and must have its own white balance set by me.
      I understand that when going into camera raw from bridge camera raw will not understand the "custom"white balance then change the white balance to "Auto" automatically upon opening image.
      How can I continue using camera raw for these Infrared images
      I can not for the life of me find access for changing this automatic change.
      Any one know ??
      Thanks Phil
        • 1. Re: camera raw/white blance
          Thomas Knoll Level 2
          The issue with white balance and IR modified cameras is the when Camera Raw uses its built-in camera profile, which was designed for non-modified cameras, the white balance parameters fall outside the temperature/tint range supported by Camera Raw.
          The real solution here would be to use a custom camera profile designed for your IR modified cameras. This would bring the white balance parameters inside the supported temperature/tint range.
          Currently there is no easy way to do this (use a custom camera profile). If you are a computer programmer, you could convert the files to DNG, and then write a program to modify the embedded profile inside the DNG.
          Short of that, I don't have any good solutions for you at present.
          • 2. Re: camera raw/white blance
            Level 1
            oooh and me without a paddle !
            Thank you for the info.
            Phil
            • 3. Re: camera raw/white blance
              Panoholic Level 2
              Could not this be solved in two phases? First converting the raw image in TIFF with WB, which comes somewhat closer to the target, saving it, and in a second pass adjusting the WB again?
              • 4. Re: camera raw/white blance
                Bill_Janes Level 2
                Since you removed the IR filter, why don't you try puting an IR filter such as the B+W 486 UV-IR Cut Filter on your lens? It also cuts UV. It might bring color balance into something you could calibrate with ACR.
                • 5. Re: camera raw/white blance
                  Thomas -
                  Is there any plan to include better support for IR white balance in future versions of Camera Raw? I use Bridge/Photoshop for my processing, but have had to buy Capture One to process my RAW IR images as it handles the white balance appropriately.
                  Peter
