11 Replies Latest reply on Mar 15, 2008 4:15 PM by Bill_Janes
    Camera Raw Color Temperature Issue
      Help me verify color temperature issue please.
      I shoot with Canon EOS 5D.
      I sat white balance mode to K - Manual Kelvin temperature - and set value to 6000K.
      So my raw files should have this setting - color temperature 6000K.
      Canon ZoomBrowser EX shows me the value - 6000K
      Nevertheless I see different reading in Adobe Camera RAW converter (as shot)?
      Photoshop CS2 Camera Raw CT=5600K Tint=+3 (! as Shot !)
      Why?
        • 1. Re: Camera Raw Color Temperature Issue
          Ramón G Castañeda Level 4
          This has been covered here ad nauseam. Please do a forum search.
          In a nutshell, the color temperature is a Canon tag that ACR ignores, but the Canon software reads it.
          • 3. Re: Camera Raw Color Temperature Issue
            Level 1
            Source:
            http://www.adobe.com/products/photoshop/pdfs/ps_cameraraw_userguide.pdf
            Note:
            The Photoshop Camera Raw plug-in can read the
            white balance settings of some cameras. Leaving the White
            Balance pop-up menu set to As Shot uses the cameras
            white balance settings. For cameras whose white balance
            settings are not recognized by the Photoshop Camera Raw
            plug-in, leaving the White Balance pop-up menu set to As
            Shot is the same as choosing Auto: the Photoshop Camera
            Raw plug-in reads the image data and makes a guess as to
            the white balance.
            Where could I find this list?
            • 4. Re: Camera Raw Color Temperature Issue
              Obviously that quote from the user guide appears to be in conflict with what Thomas Knoll, the creator of both Photoshop and of Adobe Camera Raw wrote in the link provided above:
              >"Adobe uses a difference camera profile than Olympus does, so the mapping between neutral grays [and] color temperature numbers is different.
              b This is true for every camera model that Adobe Camera Raw supports."
              Let's hope someone from the ACR team jumps in to clarify.
              • 5. Re: Camera Raw Color Temperature Issue
                Panoholic Level 2
                I don't see any contradiction here. Using the camera's WB setting does not imply, that the same number has to be displayed by different programs. Regard this as for example using different co-ordinate systems, Cartesian vs. polar vs. spherical system - these are different approaches of describing a point in some space. Different numbers can describe the location of the very same point, depending on the system.
                The point is not that the same numbers appears in camera and in ACR, but that the same effect is achieved. If the camera's own raw processor produces an image containing a grey subject, then the result of ACR too has to show that subject as grey.
                • 6. Re: Camera Raw Color Temperature Issue
                  Correct and different profiles will necessarily produce different numbers, as Thomas says.
                  Thanks for your input, G.
                  • 7. Re: Camera Raw Color Temperature Issue
                    Ramon seemed to have the answer in hand, then G Sch above chimed in with some random comment about coordinate systems. Weirdly, Ramon then agreed with G Sch's nonsense and thanked him for it. Suddenly the thread has suffered an ineluctable defenestration.
                    Is:
                    - camera maker's control for XXXX Kelvin wrong?
                    - Adobe's control for XXXX Kelvin wrong?
                    - the use of the designator "K" in these contexts wrong, as it implies physics reference for the measure while the camera and ACR just do their own thing?
                    By the logic used in this thread, 1/250sec shutter doesn't have anything to do with a time standard, nor does F4 mean an aperture, it's just a coordinate in a locally defined system, la la la. So why bother to even code it in EXIF? What's the point of providing a control in terms of K if K isn't normalized?
                    The question was answered at Ramon's first post: ACR doesn't read the 5D white bal metadata. The camera K setting is used for in-camera processing and by Canon utilities. But note that the raw data are white bal agnostic but white bal results are subject to a camera profile which may differ between OEM and ACR, and at which point there is room for discrepancy for interpretation of color. Which one is right? I can't say. It's important to realize the results for a given K setting may differ between OEM and ACR because of this. Contrary to what G Sch writes above, the same K setting ought to give the same results if a "Kelvin" setting is to have real meaning, but the seems to be impracticable if the developers don't agree on the characterization of the gear.
                    • 8. Re: Camera Raw Color Temperature Issue
                      I did no such thing. :)
                      I agreed with a single phrase in that post, the one I quoted:
                      • 9. Re: Camera Raw Color Temperature Issue
                        michael shaffer Level 1
                        'K' or "degrees Kelvin" is not an accurate measure of the color of light. EG, 6500K is taken from Kelvin's measure of the approximate color of black body radiation -- IE, it is not an accurate measure of the color of light under slightly overcast skies. EG, 6500K is not the same as D65.
                        Digital cameras need to simplify the Wb numbers without refering to how complex the 'K' number is relative to slight variations of tint. I'm not a color scientist, but refering to one Wb number relative to another is more complex than what a digital camera's menu options, or EXIF, general provides for a user or a raw developer.
                        That's my take ...
                        cheerios :o)
                        • 10. Re: Camera Raw Color Temperature Issue
                          MadManChan2000 Adobe Employee
                          Actually, ACR does.
                          There are no camera K settings. There are scalar multipliers that control the gains required to the R, G, and B camera values to achieve white balance. This is related to the correlated color temperature, but the CCT itself is generally not stored.
                          > differ between OEM and ACR.
                          True. Every raw converter applies its own math given the camera multiplier values to obtain the white balance. Similarly, each raw converter has its own math to compute CCT Kelvin values, assuming they are shown and displayed to the user in the first place. Since each raw converter has separate math used, the resulting displayed Kelvin values may be different.
                          That's assuming the camera profiles applied are the same in all cases. But they're not the same, since each raw converter has its own set of profiles. So the results won't be the same.
                          Eric
                          • 11. Re: Camera Raw Color Temperature Issue
                            Bill_Janes Level 2
                            A Kelvin temperature will accurately describe the spectral power distribution (SPD) of a black body radiator. For non-black body light sources, correlated color temperature (CCT)is used and for every CCT there are infinite numbers of SPDs. Refer to the illustration on Wikipedia showing lines of constant correlated color temperature. Unfortunately, color temperature does not fully describe the color of illumination--D65 describes a specific SPD while 6500K can have a large number of different SPDs.
                            http://en.wikipedia.org/wiki/Color_temperature
