1 Reply Latest reply on Jul 14, 2008 11:22 AM by JimHess-8IPblY
    Apply ACR autowhitebalance as an action to multiple images?
      Is it possible to select a folder of TIFFS, have them be opened in Camera Raw, and use some sort of preset such as auto white balance and a few other tweaks and have them save over the group with those adjustments?
      I suppose this is similar to asking if it is possible to set up an action inside camera raw to work on folders of tiffs that I would like to tweak in ACR.
      So far, I have been unable to find a way....
      Thank you.
      I am running CS3 on a mac with OSx.
        • 1. Re: Apply ACR autowhitebalance as an action to multiple images?
          JimHess-8IPblY Level 3
          It is not possible to open a "folder" of images as such. But you can open that folder in Bridge, highlight all of the TIF images, and then open them as a group in Camera Raw. Then, in Camera Raw, you can select all (there is a button for this) and then any adjustments you make to the previewed image will be applied to all images. Or, you can make the adjustments to one image, then select all, and click on the Synchronize button. Using that method you can choose which settings should be synchronized.
