This content has been marked as final.
Show 1 reply
1. Re: CS3.3 New Integration of Fireworks or Dreamweaver with Version Cue?
(Markus_Jasker) Aug 28, 2008 7:36 AM (in response to David C Johnson)Hi Sergei, no, unfortunately the integration for those two products is not part of CS 3.3.
You still will be able to add versions of assets if you add them via Bridge or put edited files into the local "Version Cue" folder of the projects in your MyDocuments /Documents directory. Synchronize them with Bridge and you have versions.
Dreamwaver should be able to use the WebDAV protocol to connect a Version Cue server.
So, I guess, the update would only bring you Acrobat 9 as additional feature.
Markus
