I'm working on a Flash CS3 map containing a lot of irregular polygons. Each polygon is a "button." That all works just fine.
I believe I'm hitting a wall though where the bounding rectangle defining each symbol overlaps. Depending on the layer order in the original SWF, sometimes hovering over one polygon selects another.
I can solve some of the issues by re-ordering the layers, but this won't fix all of them by any means.
Is there a setting in Flash CS that specifies Flash is to use the actual shape of a polygon rather than a least-fit rectangle?
If it's not obvious, I'm new to CS. One of my difficulties is determining what Flash calls this least-fit bounding rectangle -- important to have a proper keyword for any search engine.
Any advice would be appreciated!
TIA --
