20 Replies Latest reply on Dec 12, 2008 6:53 AM by (mitch_lukin)
    Error Message: CORE USER CREDENTIALS NOT FOUND
    Level 1
      I was prompted to automatically update Digital Editions 1.5, which I did. I'm on the same computer I've always had. I authorized the computer; however, now when I try to access my library, I get this message:
      Error W_ADEPT_CORE_USER_CREDENTIALS_NOT_FOUND
      Document is licensed for a different user account
      I used my regular email address and password to authorize the computer. Can you help? Thanks.
        • 1. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
          Level 1
          I am also having the same problem.
          • 2. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
            Level 1
            I have that problem too, but only with my library books. The ebooks I bought off the Internet are still functioning. (I had to delete and re-install them, though). It just says 'No record for this loan is not found on the machine. I tried to download other library books, but it was just doing the same thing.
            • 3. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
              BWolfe [ADOBE] Level 3
              There seem to be a couple of these errors that have popped up since launch, but I don't remember seeing anything similar during the beta. I'm not sure what the cause is yet, but have a mail out to engineering to discuss.
              Regards,
              Bentley Wolfe
              Senior Support Engineer, Flash/Flash Player
              Adobe
              • 4. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                Level 1
                I downloaded DE1.5 and now I can't download ebooks. The first time, the ebook downloaded ok however it would not open in Adobe Digitial Editions. The following error was obtained.
                Adobe DRM Error
                System: 5
                State: 4
                Class: 400
                Code: 41
                Message: Error on response from server.
                Scroll below or view error.log for more details.
                Adobe DRM client Error: 441
                Could not authenticate with voucher engine at server
                Server Code: 500
                500 Internal Server Error
                (5) Could not obtain voucher
                Exception ActiveVE [issueVoucher]:
                Code: 0x8000002b (-2147483605)
                ActiveVE Failed, code = 43 (Voucher Engine SQL Database not open)
                ActiveVE TRACE:
                I've just tried to open the downloaded title in Adobe Digital Editions again however it will not allow. I have gone to Item Errors and the error message is below.
                Adobe DRM Error
                System: 5
                State: 4
                Class: 600
                Code: 106
                Message: Error on request or response from server.
                Please check your network connection and try again.
                Adobe DRM client Error: 706
                Unexpected error during HTTP request to voucher server A connection with the server could not be established
                Can you advise what may be the problem?
                • 5. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                  Alison EBL, please open a support web case at http://www.adobe.com/support/contact.
                  • 6. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                    Level 1
                    My letter really is the same as Becky's; no choice but to download, then the error message, and now the library is "unopenable." I deleted the entire Digital Editions program and re-installed it, yet I have the same problems.
                    When I called Cust. Service--they sent me here, telling me that even within the first few entries, I'd see my problem addressed.
                    Any answers? Thank you.
                    • 7. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                      -- Delete the bad book from the library.<br />-- Close Digital Editions<br />-- Copy the copy of this book from C:\Documents and Settings\<username>\My Documents\My Digital Editions\ebx_backup to the Desktop.<br />-- Turn the error log on (Ctrl+ Shift+T)<br />-- Add the book from the desktop to the Library.<br /><br />If that process fails then please open a support case, point the agent to this thread and then attach the error log ( error.log will be in My Digital Editions folder:<br /><br />On Windows: C:\Documents and Settings\<username> \My Documents\My Digital Editions)<br /><br />Regards,<br /><br />Bentley Wolfe<br />Senior Support Engineer, Flash/Flash Player<br />Adobe
                      • 8. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                        Level 1
                        Thank you for your reply. I can't open ANY of the books--they're all "bad." Also, your instructions appear to be for a PC; I use a Mac.
                        • 9. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                          Yeah they were, I should have thought of that possibility.
                          On the mac, the 'my digital editions' folder is located in your My Documents folder. You should be able to find the files I mentioned there. If you have trouble post back. My mac is dead just now but I can check another machine later if necessary...
                          • 10. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                            Jim Lester Level 4
                            On mac the "my" prefix isn't used so this will be the "Digital Editions" folder in your "Documents" folder under your home directory ("~/Documents/Digital\ Editions" in Unix terms)
                            Error logging on the Mac can be turned on using Command (Apple) + Shift + T.
                            Jim Lester
                            Adobe Systems
                            (Team Mac Guy)
                            • 11. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                              Thanks Jim. I have to get my mac fixed :(
                              • 12. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                Level 1
                                I deleted one of the "bad" books from my library; closed Digital Editions; found the digital editions folder in Documents; copied it onto the desktop; turned the error log on; copied the book onto the desktop; and added the book from the desktop. Now the status shows as "missing" and I get this message:
                                IO Error on Network Request.
                                Network Path:
                                http://acs.contentreserve.com/ACSStore1/1204/{84A4EBB8-C68C-4A57-8CA6-7D397032C145}.pdf
                                Event Detail:
                                Error #2038
                                --- end ---
                                • 13. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                  Level 1
                                  I have the same problem. I'm using an Asus R2HV running Windows Vista. Have been downloading and reading books from www.netlibrary.com for several months now without a problem. Four days ago I was prompted to update to version 1.5 and authorize. I have done this. Now when I download the books I get the following error:
                                  - Internal Error - document already failed.
                                  Error Details "Error W_ADEPT_CORE_USER_CREDENTIALS_NOT_FOUND" and "No record for this loan is found on this machine"
                                  I tried the fix in Post #7 - it does not work. I deleted all Adobe from my PC and re-loaded and re-verified everything. Still does not work. What now?
                                  • 14. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                    Level 1
                                    Can you please help?
                                    Yesterday (05/17/08) I opened my Adobe Digital Editions program and was prompted to load an Adobe update. During the process of loading that update, the program suggested that I select an option which authenticates my computer. The update appears to be complete, but the problem is I can no longer read my ebooks. I can see them listed, but when I try to open I get the following error.
                                    All my ebooks are very expensive, and I just purchased one for an upcoming class which starts next week.
                                    My system info:
                                    OS Name Microsoft Windows 2000 Professional
                                    Version 5.0.2195 Service Pack 4 Build 2195
                                    Jesse Gonzales
                                    Jesse_j_gonzales@hotmail.com
                                    • 15. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                      Level 1
                                      I have a similar problem. I was forced to download an update for Digital Editions. I was prompted to authorize my computer. After I did this, my entire e-book library is now unavailable. The error message is:
                                      Error W_Adept_Core_User_Credentials_Not_Found
                                      Document is licensed for a different user account.
                                      These e-books cost me more than $100 total. One of them I need for class immediately! Please help me resolve this issue ASAP.
                                      • 16. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                        Level 1
                                        I am experiencing the same problem. After downloading the newer version I received the message below when trying to open one of my books.
                                        I tried deleting all the books and adding them back in to the library. This did not work. It made it worse. Since then I have restored my computer to the previous day to keep my books from being corrupted. I am now waiting to try and download this program again. I do not want to download until a solution can be found. Anxiously waiting for solution.
                                        Mahalo,
                                        Susan Abeshima
                                        susanabeshima509@hotmail.com
                                        • 17. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                          Level 1
                                          I am having the smae problems. Has any one found a solution yet.
                                          • 18. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                            We are working on determining what's causing this. It would be helpful if everyone with these issues would open a support case at http://www.adobe.com/support/contact.
                                            • 19. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                              Level 1
                                              I contacted my library' support team and they came up with a solution. However, I'm not sure it will work for those who are unable to redownload titles (from my website, I'm able to download ebooks a second time....)
                                              This is what they said:
                                              1. Open Adobe Digital Editions and delete the title you are having
                                              trouble with. Then close Adobe Digital Editions.
                                              2. Open the 'Control Panel'.
                                              3. Open 'Folder Options' and select the 'View' tab.
                                              4. Select 'Show hidden files and folders'.
                                              5. Un-check 'Hide protected operating system files'.
                                              6. In the warning message you receive, click 'Yes'.
                                              7. Click 'OK'.
                                              8. Close the Control Panel.
                                              9. Navigate to the following location:
                                              C:\Documents and Settings\(user name)\Application Data\ Adobe\Digital
                                              Editions\
                                              10. Delete the Voucher folder.
                                              11. Navigate to My Documents / My Digital Editions. Delete the PDF
                                              file for this title.
                                              12. Also in the 'My Documents / My Digital Editions', delete the
                                              manifest.xml file.
                                              13. Navigate to My Documents / My Digital Editions / ebx_backup.
                                              Delete the PDF file for this title.
                                              **** The following steps involve modifying the registry. Please be VERY
                                              careful and do not delete or rename anything else in the registry
                                              besides the items mentioned below.
                                              14. Click 'Start > Run'.
                                              15. Type 'Regedit' and click 'OK'.
                                              16. Navigate to 'HKEY_CURRENT_USER\Software\Adobe\Adept\Activation'.
                                              17. Here you will see several folders, numbered 0000, 0001, 0002, etc.
                                              Click once on '0000'. In the right pane, you should see one entry with
                                              something in the 'Data' column. One of these folders (0000, 0001, 0002,
                                              etc.) will have 'loanToken' for the data. Expand this folder.
                                              18. Inside the 'loanToken' folder, you will have more folders numbered
                                              0000, 0001, etc. Select them one at a time. You should see several that
                                              contain a name of (Default) with Data of loan. Delete each numbered
                                              folder (0000, 0001, etc.) that contains the (Default) loan inside it.
                                              19. Close the registry and open Adobe Digital Editions. It should open
                                              without error.
                                              20. Return to the library website and try the download of your title again.
                                              Hope this helps!
                                              • 20. Re: Error Message: CORE USER CREDENTIALS NOT FOUND
                                                Level 1
                                                Becky -
                                                I am having the same problems reflected in this thread and others which include the "Internal error - document already failed" error message. I have tried all of the suggested fixes, and tried opening a new case, but have heard nothing back. Have y'all had ANY success in dealing with these issues? It is quite frustrating.
                                                Mitch
