1 Reply Latest reply on Jun 20, 2007 12:30 PM by (Ric_Wright)
    Viewer Does Not Work With Latex-Generated PDF's!!!
      for example, try using PDFlatex to generate a PDF from latex and you will see that Adobe Digital Editions does not render the text.
        • 1. Re: Viewer Does Not Work With Latex-Generated PDF's!!!
          Level 1
          Latex often generates (by default?) text using a font which is of the type "Type 1 Symbolic". This is a very old type of font (now deprecated ) which is supported by Acrobat and Reader's PDF engines, but is not supported by the PDF engine used by Digital Editions. Since we do not know which font you are using, we cannot be sure, but suspect this is the case. Can you tell us exactly what font(s) you are using? Thanks.
