20 Replies Latest reply on Dec 29, 2009 6:26 AM by MLK1941
    Cannot copy from Digital Editions1.7 to Sony e-reader
    JSC Galloway
      I downloaded version 1.7 when buying books from Waterstones. These books arrived in DE but now I cannot copy them across to my e-reader.
      Have tried Adobe web site but cannot get into their Technical Site.
      Anybody help.
        • 1. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
          Level 1
          I have exactly the same problem
          I have followed the instructions Adobe sent me and am still no further forward.
          In the instructions it says plug in you Sony eReader and Digital Editions will detect it.
          It does not.
          If I select "Library" - Authorise Computer...
          It tells me that my laptop is already authorised.
          I have spoken to Sony and the eReader is working perfectly.
          I have the book Bill Hybels - Just walk across the room in my Digital
          Editions. I can read it in ADE but cannot transfer it to my Sony eReader.
          I also have it in my eBook library but if I try to drag and drop it into the reader (which eBook Library can see) it gives the following message
          "To transfer this eBook you must first authorise the Reader for Adobe DRM
          protected content. Would you like to launch Adobe Digital Editions"
          Yes/No. If I select yes it opens Adobe Digital Editions and I am back
          where I started.
          Please please help as I am getting very frustraited.
          Someone must know the answer.
          • 2. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
            BWolfe [ADOBE] Level 3
            Brian, try control-shift-E (with the PRS plugged in to your pc). This should force an activation of the PRS. I've found it's a bit sensitive to the sequence the keys are pressed so try it a couple of different ways. If you can get the authorize dialog to come up then you can authorize your PRS to your AdobeID (matching your authorization of Digital Editions). Then you should be able to transfer your books.
            • 3. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
              JSC Galloway Level 1
              Have tried the Control-Shift-E but the only message I get is "Please select the devic eyou wish to deauthorise".
              Anybody any ideas?
              • 4. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                Well this means that your device is already authorized...
                you should be able to see it as an added book shelve and should also be able to exchange books between your ereader and other book shelves
                • 5. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                  Thank you, thank you, thank you for the suggestion CTRL-Shift-E!! I have spent DAYS working on this problem! Now I can get free digital book editions from my local library site! Love it!
                  Linda
                  • 6. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                    Hi!
                    I have exactly the same problem described by Brian Crockett. I'm running Windows XP (with SP2) on a Dell.
                    I plug in the Sony PRS-500 reader but DE doesn't recognise it. The device is not listed in the sidebar and I can't transfer any DRM-protected books to it (not even the free sample eBooks from the Adobe website!)..
                    If I visit the menu item "Authorize Computer" it tells me the computer is already authorised.When I try to transfer a purchased eBook I get the same message that Brian described - telling me to authorise the reader.
                    I tried Ctl-Shift-E as you suggested (with the device plugged in) but DE doesn't respond and the authorise dialog diesn't come up.
                    Is there anything else I can try?
                    Many thanks
                    John
                    • 7. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                      Jim Lester Level 4
                      John,
                        It's not quite the same problem for you, unfortunately.  You are using a Sony Reader 500, which is not compatible with ADE.  Only Sony Readers 505 and 700 will work with ADE.
                      Jim Lester
                      Adobe Systems
                      • 8. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                        Level 1
                        Hi Jim,
                        Very sorry, that was a typo! Its a PRS-505.
                        Can it be an XP problem? After posting my message, I loaded ADE onto my
                        laptop (with Vista) and tried attaching the device to it. Everything
                        worked perfectly, and it even automatically authorised the blocked DRM
                        book that I'd previously loaded onto the device.
                        So I have my "workaround", but it still doesn't work on the XP machine.
                        Best,
                        John
                        Jim Lester schrieb:
                        John,
                          It's not quite the same problem for you, unfortunately.  You are using a Sony Reader 500, which is not compatible with ADE, which will only recognize Sony Readers 505 and 700.
                        Jim Lester
                        Adobe Systems
                        • 9. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                          Jim Lester Level 4
                          John,
                            I would make sure you have latest version of the Sony Software on your XP computer (and potentially re-install it anyway).   ADE relies on a driver installed by Sony to communicate with the Sony Reader.
                          • 10. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                            Lazzard
                            I have the exact same problem as Brian, with the added complication that the PRS-505 icon appears in the Adobe DE navigation bar.
                            Still can'y transfer to my reader, when in Ebook-library I get the same 'do you want to autorise?' message. And then,like Brian, when I click Yes, nothing happens. Ctrl_shift+E does nothing. All software/firmware is up to date.
                            It's REALLY winding me up.
                            BTW I live in UK and bought the reader in UK
                            • 11. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                              wronawoman
                              I have exactly the same problem as Brian. The Adobe DE does not see my Sony PRS-700 when it is connected. I have uninstalled and reinstalled the Adobe program to no avail. I have the latest Ebook Library software,did the "Ctrl-Shift-E" and nothing happened.
                              I'm not unsophisticated in debugging problems but this has been a royal pain in the neck! Oh yes, the manifest.xml file had no de:AdobeID so there was nothing to get rid of.
                              Needless to say, after three hours of effort, I decided that ebook software still has a way to go. Adobe may have a good product in Adobe DE but, I'll not find out using my Sony reader and so will blow off the Adobe. This stuff is suppose to be simple!
                              What a waste of time!
                              • 12. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                Elle Sue
                                Hello. Very new to this.  I've read these answers and they don't seem to answer my query.
                                Have bought Sony e-reader; installed e-library and Adobe Digital Edition on pc; bought book from Waterstones.
                                Can see book in ADE but it isn't anywhere to be found in the e-library, and I don't know how to transfer it from ADE to either the e-library or the Reader.
                                [At the moment, somewhat academic as can't get e-reader to switch on having switched it off, but no doubt that will sort out! ]
                                Please, can anyone give me idiot proof non technical step by instructions for transferring book from ADE to e-library and or Reader.
                                Thank you very much.
                                • 13. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                  Chris Bulmer
                                  I have exactly the same problem, I have a Sony ebook reader PRS-700 and cannot seem to get adobe digital editions to recognise it in order to authorise it. I have tried Ctl Shft E without any success, I bought the device whilst in the US but I am actually from the UK and was wondering if this could be the cause of the problem? I have to admit I am getting very frustrated with the whole thing, I've bought several books for my ebook reader and it all seems to have been a waste of money! If anyone can help it would be much appreciated.
                                  • 14. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                    zbloom
                                    I have a related problem:
                                    I can download ebooks from my local library, they open on adobe digital
                                    editions. Adobe digital editions recognizes the PRS-505 and the
                                    files can be dragged to it.
                                    On the PRS-505 the files are listed with today's date but without an
                                    expiration date, and when I click on one of the files I see it
                                    listed as being only one page with an error message saying "Protected
                                    page."
                                    It seems that the permission for the PRS-505 to view the file is not being handled properly.
                                    This does not occur when I use the ebook library program to drag unprotected pdf, txt, or doc files to the PRS-505.
                                    Any ideas?
                                    Zach Bloomgarden
                                    • 15. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                      Connie1116
                                      I agree. I just got me 700 & the only issue I have with it is that DE will not recognize it so that I can authorize the reader.  I have emailed Adobe but still have not gotten a response yet.  Have done the Control-Shift-E but nothing happens?  I have Vista on my computer also.
                                      Connie
                                      • 16. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                        zbloom Level 1
                                        I've gotten several unhelpful responses - the reader does work perfectly
                                        with unprotected txt, doc, and pdf files using the sony reader program, so
                                        it's just a problem with the adobe protected format - unfortunately that's
                                        what I can get from the public library!
                                        Zach
                                        • 17. Re: Cannot copy from Digital Editions1.7 to Sony e-reader
                                          eReading in Dublin
                                          For the past 3 days been battling a flue as well as the e-Reader. Thanks to some
                                          great replies in amongst others the Adobe forum I've figured out the following
                                          (thought to be helpful instead of only searching for answers):
                                          • I have a Sony e-reader Touch
                                          • You can not order books from the US or use the US Sony Library software w built in store version in Europe (rights issues I suppose)
                                          • Over the holidays it took years to download the UK version which finally worked
                                          • Via the eBook Store I happily bought some books - i.e. through WHSmith as this site works with 3rd party providers
                                          • Not having been told about DRM protected files I found myself with 3 unuseable files
                                          • Uninstalling, reinstalling, authorizing, de-authorizing, the whole lot
                                          • Finally learnt that for DRM protected files you need Adobe Digital Editions, as well as an Adobe ID
                                          • For Adobe Digital Editions to show your e-reader YOU HAVE TO HAVE SONY LIBRARY SOFTWARE INSTALLED as it seems to have a driver which Digital Editions needs to talk to the e-reader. without it you won't see your e-reader
                                          • Of the 3 books I bought only one managed to be copied to Digital Editions, when I try to copy the others (just drag the downloaded files onto the Library in DE) the message says more or less
                                          • 'error asking for license - problem communicating with license server
                                            : E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER'
                                            Concluding I find it quite disgraceful how something so consumer geared can be so user-unfriendly. I saw that I was not the only one fuming over the holidays ...
                                          • a great contributor to the forum pointed out that in buying from WHSmith they probably set me up with a transaction ID which is interfering with the Adobe ID. (one wonders though how I managed to get one book onto the Digital Editions Library and from there onto the e-reader). Becase they are closed over Xmas and even today (Monday 28 Dec) I will call them tomorrow and hope they can set that right. (Jim's answer was
                                            The one you have has a transaction ID which is associated with, which has already been used to create a license for a different user (E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER).  In this case the other user is the original anonymous activation that you wife orginally had on the computer.')
                                          • What I haven't figured out yet is why the Sony software, upon connecting the e-reader, wants to install software and always fails ... Or why the DRM protected books can sit in the Sony Library software (can't move them to the e-reader though) and not in the Adobe Digital Editions Library.
