This content has been marked as final.
Show 8 replies
1. Re: RoboHelp menu and capture in TCS 2?
(Jeff_Coatsworth) Mar 6, 2009 9:23 AM (in response to Seanb_us)Hi Sean,
I'm using the TCS 2 also, but all the links I see are from FM to RH (which sort of makes sense, since the assumption is that you're authoring in FM and then "publishing" to help using RH). So I wouldn't expect to see any RH buttons in FM. -
2. Re: RoboHelp menu and capture in TCS 2?
Seanb_us Mar 6, 2009 10:41 AM (in response to Seanb_us)What do the links from FM to RH look like? I don't have any.
Cheers,
Sean -
3. Re: RoboHelp menu and capture in TCS 2?
adrianaharper Mar 6, 2009 11:02 AM (in response to Seanb_us)Hi Sean,
I am using TCS. I have a couple of links to RH from with FM (that I have found so far). When I'm in an FM document-
1-under File, Launch RoboScreenCapture is listed in the menu
2-when I select a graphic in one of my FM files, under Graphics, I have Edit with RoboScreenCapture
HTH!
Adriana -
4. Re: RoboHelp menu and capture in TCS 2?
Seanb_us Mar 6, 2009 11:09 AM (in response to Seanb_us)Adriana,
That is great. I missed those in the File menu -- was looking for menu items up top. That does help.
Anyone know how FrameMaker is connected to RoboHelp through the GUI? Or, are those links only in the RoboHelp application?
Cheers,
Sean -
5. Re: RoboHelp menu and capture in TCS 2?
(Jeff_Coatsworth) Mar 12, 2009 11:25 AM (in response to Seanb_us)Hi Sean,
The links are in RH - when you create a new project in RH, you can link FM books and files to appear within the project. Once linked, the project icons show you whether or not the FM book/file has changed and needs to be updated. You can specify what & how FM paragraph and character formats will appear and how they look in the Project Settings of the project. You can also choose whether or not you import glossaries and indices from your FM books. -
6. Re: RoboHelp menu and capture in TCS 2?
Seanb_us Mar 12, 2009 11:41 AM (in response to Seanb_us)Thanks. Will give it a go.
Cheers. -
7. Re: RoboHelp menu and capture in TCS 2?
adrianaharper Mar 12, 2009 11:58 AM (in response to Seanb_us)Hi Sean,
You will find some good tutorials here -
http://www.adobe.com/devnet/robohelp/
The "Adobe Technical Communication Suite: Getting Started series" is good- a bit long at times, but helpful regardless. Specifically, try "Part 3: FrameMaker 8 and RoboHelp 7: Natively reuse FrameMaker documents in RoboHelp" for info on integrating FM with RH.
HTH,
Adriana -
8. Re: RoboHelp menu and capture in TCS 2?
Seanb_us Mar 12, 2009 12:21 PM (in response to Seanb_us)Thanks. I appreciate the link.
