1 Reply Latest reply on Aug 6, 2008 9:13 AM by Newsgroup_User
    Method marked override must over ride another method
    josh_aries Level 1
      Hi ,
      I am working on validating a Radio button group validator.
      Here is the code that I have. I get the following error for the override methods
      Severity and Description Path Resource Location Creation Time Id
      1020: Method marked override must override another method.
      Thanks in advance
        • 1. Re: Method marked override must over ride another method
          Level 7
          You're not extending anything, so there is nothing to override.
          HTH;
          Amy
          "josh_aries" <webforumsuser@macromedia.com> wrote in message
          news:g7chur$sg4$1@forums.macromedia.com...
          > Hi ,
          > methods
          > Thanks in advance
          > package com.test.validators
          > import mx.controls.RadioButton;
          > import mx.controls.RadioButtonGroup;
          > import mx.validators.StringValidator;
          > public class RadioButtonGroupValidator
          > private var _radioButtonGroupInitialized:Boolean = false;
          > public function RadioButtonGroupValidator() {
          > super();
          > override function doValidation(value:Object):Array {
          > if (!_radioButtonGroupInitialized && (source is RadioButtonGroup ||
          > listener
          > is RadioButtonGroup)) {
          > removeListenerHandler();
          > addListenerHandler();
          > return super.doValidation(value);
          > // Overridden properties
          > // actualListeners
          > * @private
          > * Returns either the listener or the source
          > * for the day, month and year subfields.
          > override protected function get actualListeners():Array {
          > var results:Array = super.actualListeners;
          > if (results == null || results.length < 1) {
          > return results;
          > var sourceElem:Object = results[0];
          > if (sourceElem && sourceElem is RadioButtonGroup) {
          > var numRadioButtons:int = RadioButtonGroup(sourceElem).numRadioButtons;
          > for (var i:int = 0; i < numRadioButtons; i++) {
          > var rb:RadioButton = RadioButtonGroup(sourceElem).getRadioButtonAt(i);
          > results.push(rb);
          > rb.validationSubField = null;
          > if (numRadioButtons > 0) {
          > _radioButtonGroupInitialized = true;
          > return results;
