Issues fixed in FM 7.1 release
Arnis Gubins Nov 11, 2004 9:49 AMAdobe FrameMaker 7.1 for English, French and German was released on January 10, 2004. The following is a list of issues fixed in this release.
250374
FDK: FA_Note_PreSetAttrValue notification not sent for new elements. If a client subscribes to FA_Note_PreSetAttrValue events, it will get a notification when one changes an attribute by double clicking it in the Structure view. However, on creation of a new element through the element catalog, if an attribute is set, no notification is sent.
This issue has been resolved.
277554
FDK: F_ApiUnStraddleCells() does not work as expected.
When unstraddling cells through the API, all the cells except the leading cell have no paragraph end marks (they are completely empty). Clicking into such cells takes the text cursor to the location of the table anchor. Inserting a character into the paragraph with the table anchor seems to correct the table.
310049
FDK: F_ApiImport shows a dialog upon import of SGML entities.
When importing an SGML fragment by reference using F_ApiImport, FrameMaker displays a dialog asking whether the text inset should be updated automatic or manually. This setting should be controlled from import-parameters.
Currently there is no way of creating a client that imports a large number of SGML text-insets without having a user sitting by the keyboard and clicking OK for each imported entity.
314764
FDK: F_ApiDelete does not work properly on elements inside a TextInset. When you try to delete an element that is part of a TextInset, the whole TextInset is removed.
The work around for this is to unlock the text before calling F_ApiDelete and to lock the text after this call. The calls to unlock and lock the text are given below:
To unlock - F_ApiSetInt(docId, insetId, FP_TiLocked, False);
To lock - F_ApiSetInt(docId, insetId, FP_TiLocked, True);
387821
Microsoft Intellimouse Scroll wheel locks up FrameMaker when it's pressed or scrolled.
408675
Rotated PDF files do not appear on 24-bit or 32-bit displays.
463533
Non-unique ID tags cause inconsistent hypertext links due to multiple entries in the HTML export. If there are conflicting IDs in different documents of a book, non-unique ID tags are generated which cause this behavior.
507486
If you edit the MAKER.INI file by adding the line SplashScreen=Off, in the [Preferences] section, then the Help->About command crashes FrameMaker with Internal Error: 7004, 6048898, 7639747, 0
529757
(don't include) Marker element gets included and merged in PDF bookmarks with previous heading. In FrameMaker 6.0, the document prints to PDF as expected--the bookmarks in Acrobat PDF contain the Section2/Heading as expected, such as:
Spark Plug Threads
and Lamp Base and Electrical Fixture Threads
In FrameMaker 7.0, the document prints to PDF with the Section2/Heading merged with the Run.head marker element, even though Run.head is in the ''Don't include'' list of elements in the PDF Setup dialog box.
534856
The value of DPDFOpenBookmarkLevel is ignored when read in a MIF file.
534865
The values Default, All, and None of the ''Bookmarks expanded through level'' field (in Format > Document >PDF setup) are not retained when a FrameMaker document is saved and opened again.
535630
Windows Metafile (wmf) graphic (created from Microsoft VISIO 2002) causes "an error occurred while printing" but partially prints.
537955
ISOdraw CGM graphics and tables on the same page cause CGM stroke lines to be printed in White.
540408
Inconsistent dialog behavior between FrameMaker 6.0 and FrameMaker 7.0 when opening filename.sgm. Unlike FrameMaker 6.0, FrameMaker 7.0 displays the Unknown Filetype dialog.
540417
Inconsistent dialog behavior between opening filename.sgm and filename.sgml.
541912
TaggedPDF:fmpdfreflow plug-in - display of PDF file not good for shaded table cells. When table cells have shading in them, the PDF file does not show all the content of the shaded cells. This happens on Windows only.
565678
PDF generation on UNIX translates CMYK colors to RGB.
567784
FP_InsetFile has a value of "BadFileName" when SGML importing misses a graphic data file. If you import an SGML file that would read external graphic files and these data files are missing, then skipping or ignoring them results in "BadFileName" pathname for each object property. This makes FDK API Client not get FP_InsetFile property value for the FO_Inset object.
569092
FrameMaker7 server can't find default printer when launched as a service.
This issue has been resolved. To suppress the errors during initialization e.g.. No Default printer, invoke FrameMaker with the -silent option.
569969
When the Paragraph Designer is open, you can't switch to open documents using the book window.
581376
FrameMaker works very slowly or returns an internal error. When processing a document that includes many EPS image files, FrameMaker creates many FRMxxxx.tmp files in the C:\Documents and Settings\Account Name\Local Settings\temp\ folder. The xxxx is a hexadecimal number. Even after quitting FrameMaker, the FRMxxxx.tmp files are NOT deleted, and the same document creates different FRMxxxx.tmp files after being opened again. The template files pile up in the hard disk for the Account/user, until the xxxx reaches ffff, the maximum number for the 4 digits of a hexadecimal number. At or near this time, FrameMaker works very slowly or stops with internal error:7004,6643018,6765315,6712018.
581522
Imported PDF document with transparencies does not print correctly.
584633
Internal Error: 7004, 6055410, 7657059, 0 when saving/printing to PDF includes Bookmarks that include index elements. The crash occurs only on Windows. The problem occurs when you attempt File > Print to PDF, when you want to Generate PDF Bookmarks based on structure elements, and have the ''Sectlevel1'' element in the ''Include Elements'' pane, and that particular ''Sectlevel1'' element plus the length of the text in the index marker entries exceeds 256 characters.
589859
Post installation of Distiller 6.0, .tps file gets retained along with PDF and log file.
592974
Opening a large XML file in FrameMaker generates error 'Internal Error 7004, 6052770, 0....
When an XML file contained more than 65520(FFF0) children elements, FrameMaker crashed.
595875
Spell check skips elements, loops around elements, or gets completely stuck.
597276
The Save as PDF command does not create a PDF file (for certain files) when Generate Tagged PDF is ON
598056
Group4 fax encoded TIFF files imported in FrameMaker 7.0 don't display nor print--does not occur in previous versions.
600053
Display/Scrolling performance is very slow with documents having TIFF images imported by copy.
600497
Scrolling a document in FrameMaker using Page Up/Down button goes to previous/next page respectively. Scrolling a document using Page Up and Page Down button goes to the previous and next page respectively. User would expect to scroll to the previous/next screen instead of going to previous/next page using these buttons, as seen in other Windows applications like MS Word, etc.
601470
Links being dropped in SVG filter. Import an SVG file by reference (and the imported file has a link to another SVG file). Save this and reopen; the referenced SVG file is missing.
603668
The text in the markers gets included in the PDF Bookmarks. Do not include textual content of marker elements, such as Index markers. This is because if you do, the Acrobat bookmarks can appear created if the element has:
where Indexterm contains the marker text:
<$startrange>PDF Creation;<$endrange>PDF:Good;How To:Create Good PDF
... You will end up with an Acrobat Bookmark containing:
How To Create <$startrange>PDF Creation;<$endrange>PDF:Good;How To:Create Good PDFGood PDF ... which is not desirable.
606704
In Server Setup dialog box, user name of the form "domain\username" does not allow names starting with b, r, etc. While trying to get FrameMaker to talk to the WebDAV server, which is using Windows authentication, when we specify a user name of the form "domain\username" in the "Server Setup" dialog box (File | Workgroup | Workgroup Servers ...). For some user names this works; for others it doesn't.
607610
Framemaker crashes when Print is selected twice from the context menu for a book.
610099
Drop Caps are not imported as TextFrames (RTFImport).
610600
Words on which cross references are created are getting dropped while importing doc file (Word2000Import). Create a cross reference on some word in MS Word, and import the doc file into FrameMaker. The word on which the cross reference is created is getting dropped.
611165
Words on which cross references are created are getting dropped while importing rtf file (RTFImport). Create a cross reference on some word in MS Word, and import the rtf file into FrameMaker. The word on which the cross reference is created is getting dropped.
611802
Text which is rotated is lost when exporting to RTF.
611900
FrameMaker locks referenced files until the application closes.
613546
The filter name in the unknown file type for import is Microsoft RTF whereas for Export it is Microsoft RTF 1.6.
616153
Contents of anchored frames not visible after save as PDF with Tags. After saving a document with anchored frames as PDF with Tags enabled, the contents of the frame are not visible in the PDF generated.
624470
footnote element mapping to Frame Footnote is commented in Rules defined for XDocBook. In application definition of XDocBook in $FMHOME/structure/xml/xdocbook/app, footnote element mapping is to FM Footnote element. However, this rule is commented since past few releases. As a result, any (xdocbook) XML document with footnote is shown as invalid in FrameMaker.
624472
Revision remark (revremark) element is mapped to different element names in EDD and rules. Rules for XDocBook in $FMHOME/structure/xml/xdocbook/app translate revremark to RevRemark. However, EDD (ECM) defines Revremark as mapping for revremark element. Hence a valid xdocbook XML document with revremark is shown as invalid (with unknown RevRemark element) in FrameMaker.
624517
Unable to open FrameMaker 7.0-created fm file, which is created by importing a Word document.
625306
Office documents don't open in FrameMaker in absence of write permissions (UNIX).
626431
For line spacing, values that are beyond range are not mapped correctly (RTFExport). For line spacing in frame document which are beyond the max or min range of RTF, the mapping is not correct and same value of line space I mapped to three different values in RTF.
626434
For stretch, values that are more than 600 are not mapped correctly in RTF (RTFExport). For stretching in frame doc that are beyond max value in RTF (600), the mapping is not correct. There is no stretching (scaling in RTF) in effect in exported RTF for values greater than 600 specified in frame.
626450
Current date and time are not getting exported properly and are coming as 0's and XXX (RTFExport).
627855
After saving as PDF, headings are centered in reflow mode. After a particular file is saved as a PDF file and is viewed in reflow mode in Acrobat, the headings are centered.
631967
Installer does not recognize existing installation.
633133
Right indents are not mapped while importing Excel
633137
Data in the Custom formatted cell is lost while importing excel sheet.
633462
FrameMaker terminates while exporting to RTF.
633710
You have to give a filename with extension, while saving a file to RTF.
638750
A PS file generated from FrameMaker with Tagged PDF on and hypertext marker in the file, cannot be distilled to PDF
638824
Dialog Box indicating Unsaved changes made to file is not displayed on closing a document after importing an image using drag and drop.
639220
If you select a Master Page or a Reference Page and select Save as PDF, PDF generation fails without giving appropriate error message.
641918
When converting a FrameMaker book to PDF: default opening page in PS/PDF may be incorrectly set to be the first page of last chapter in a book.
642765
On drag and drop of a SVG file into FrameMaker, if you click on the cancel button on the Import SVG dialog, the cancel is ignored and the file is imported.
643092
If United Kingdom is chosen as the country of purchase, the EULA contains the string "FrameMakerDesktop _USEnglish_1.21.02_17:29".
644158
Following alerts can not be suppressed via command line option:
. Register now/later/never
. Adobe Online
These can be now suppressed using the -noaol command line option or by using the DisableAdobeOnline=On option in the maker.ini file.
644904
An empty merged cell(256 columns) created in Excel imports as a blank file.
645230
If you import a Word document having large number of footnotes in FrameMaker, the footnotes are overlapped.
645538
Cross reference text when exported to RTF has an additional space after the cross reference text.
645863
When an excel file containing cells applied with custom formatting is imported in FrameMaker, the font and color of these cells is different in FrameMaker.
646609
When a specific excel file is being imported the data in the first cell is lost.
646676
When saving a MIF file, then opening it in FrameMaker, the DPDFZoom settings are lost.
647770
User defined variables with _ in their name when saved to xml and opened again in Frame, round-trip as fmv1, fmv2 ...
648043
When you try to open/import a file with a name containing more than two % signs and at least 1 non-% character between the second and third % sign then FM gives an error saying the file is non-existent
648114
Info>Copyright>More crashes FrameMaker
648434
When you import an RTF file with a cropped image in FrameMaker, it is imported in its original uncropped form.
649640
When a word document having text with decimal numbering is imported, the sub points (1.1,1.2,...) are imported as (0.1,0.2,..)
650631
When you import a word document having numbering points with comment on each numbered point, the font size of the numbering point is reduced.
650962
FrameMaker crashes on scaling any anchored frame on reference pages.
652229
When you import a word file with ascending raised/lowered baselines then they are not imported correctly.
652433
When you import an excel file containing date formatting having mm format, FrameMaker inserts an extra zero before the date.
652752
If you install FrameMaker from network, the short cut to readme file opens it in notepad.
652794
The alert Inconsistent settings in Book" during F_ApiSilentPrintDoc() can not be suppressed.
654309
When you import a word document having numbering (1.1,1.2,..) placed after some non-decimal numbering(1,2,3), FrameMaker imports it as (3.1, 3.2,..).
654348
When you save an inline image as .doc in Acrobat6 and import this word file in FrameMaker, FrameMaker enlarges the graphics on import.
655072
When you have an user defined variable in the frame document as well as the template, you save this document as XML and open the XML file again in frame, the template definition overrides that of the document.
655726
Full license number is displayed in the Help>About FrameMaker 7.0 screen.
656171
Full license number is displayed in the FrameMaker 7.0 Splash screen.
656820
If you zoom or move frames after importing a graphic in FrameMaker, Framemaker logs out the user from Unix machine.
657053
If a frame document displays images from the reference page and you simultaneously open multiple such documents, then the images from the document opened first can replace the images in the other documents
658744
If you open an XML file locked by some other application, FrameMaker shows a Validation Error dialog box. For this to work, the XML locking feature should not be switched off.
658749
The German version of Online manual xmlcss.pdf has comments in it.
Known Issues
The printed user guide, on-line help and QRCs will not change between the FrameMaker 7.0 release and FrameMaker 7.1. Certain online manuals will be updated, and a new online supplement will be added to cover user documentation of the new release.
[Original message from Forrest_F accidentally deleted when Forum re-organized]
250374
277554
310049
314764
387821
408675
463533
507486
529757
Spark Plug Threads
534856
534865
535630
537955
540408
540417
541912
565678
567784
569092
569969
581376
581522
584633
589859
592974
595875
597276
598056
600053
600497
601470
603668
606704
607610
610099
610600
611165
611802
611900
613546
616153
624470
624472
624517
625306
626431
626434
626450
627855
631967
633133
633137
633462
633710
638750
638824
639220
641918
642765
643092
644158
. Adobe Online
644904
645230
645538
645863
646609
646676
647770
648043
648114
648434
649640
650631
650962
652229
652433
652752
652794
654309
654348
655072
655726
656171
656820
657053
658744
658749
Known Issues
