3 Replies Latest reply on Jul 8, 2008 1:42 AM by (Peter_Robisch)
    Strong DITA integration into FM Technical Communication Suite
      My motivation to vote for a strong DITA integration is that I can imagine the FM Technical Communication Suite as an very appropriate tool to support the DITA Learning and Training Content Specialization in a smart way.
      That's important as on April 1, 2008 the DITA Technical Committee has approved Design Proposal 12058 for inclusion of the DITA specialization for learning and training content in the formal design plan for DITA 1.2.
      My long-term vision for the FM Technical Communication Suite is, for example,
      * write your quiz is FM and use it in Adobe Captivate
      My short-term vision the for the FM Technical Communication Suite is
      * improve the usability of the DITA plugin for technical writers
      Looking forward to a user-to-user discussion about which smart DITA integration into the FM Technical Communication Suite.
        • 1. Re: Strong DITA integration into FM Technical Communication Suite
          Level 1
          b Smart Language Identification
          GOAL
          FM DITA plugin uses the xml attribute for language identification
          to set
          Proposal
          The language identification attribute is
          xml:lang
          see
          http://www.w3.org/TR/2000/REC-xml-20001006#sec-lang-tag
          A scretch of an implementation:
          Change the entry for the attribute xml:lang in the related EDDs from
          Name: xml:lang String Optional
          to
          Name: xml:lang Choice Optional
          Choices: en-US | de-DE
          Default: en-US
          Note: en-US means language(englisch)-country(USA)
          A smart integration would
          * language-country codes for all combinations supported by FM
          * May be the drop-down list of
          ParagraphFormatting/PropertiesFont/Language
          can view the lanuage-country codes, too
          * TextFormatRules similar to this one are necessary
          If
          Specification Concept[xml:lang="de-DE"]
          ParagraphFormatting
          PropertiesFont
          Language
          Deutsch
          Well, my current workaround is I add a version of the above TextFormatRule to all elements which are specificied in the 'info-types' variable of the topic.edd
          Any smarter workarounds known?
          • 2. Re: Strong DITA integration into FM Technical Communication Suite
            Level 1
            b improve format rules of <ul> in <linkinfo><br /><br />b Issue<br />  While there is an indention use by linkinfo, <br />  using an ul item does not have such an idention<br /><br />(I keeps this here for bug tracking.)<br /><br />BTW would it be nice if Adobe would open a plattform the DITA related edd are under source control and bugtracker informs about the tought behind the changes.
            • 3. Re: Strong DITA integration into FM Technical Communication Suite
              Level 1
              b Better text editing support in the structured view
              b Issue
              Of course for writing structure documents the structured view is the main feature one will use. FM currently only display the first characters of an text entry. You type further, but you want see the written text in the structured view. You always have to bring in front the normal text view to see the written text.
              This limitation of FM is one which strongly minimizes the usability. IMHO this limitation does not make sense any more as computer nowadays typically are more powerful and screens are much broader today.
              b Proposal
              In the old days of computer programing 80 characters was the optimal column width. So I propose to wrap by a width of 80 characters in structure view. (If someone really has a too small screen he might use an option to change the wrapping width. )
