• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
6
How do I crop a photo in Illustrator?
New Here ,
May 28, 2008 May 28, 2008
I can't believe I can't figure this out. (I came over from Freehand, and it was simple).
All I want to do is:
1) Crop a placed photo within Illustrator
2) Create a border around it.
I can't seem to find the answer in any help file. Is it so simple in Illustrator that they don't explain how to do it? I don't want to create crop marks for the entire image, just crop off part of a photo without going back into Photoshop. How?
Thanks very much.
Mark
Views
2.2M
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
replies 111 Replies 111
Engaged ,
May 29, 2008 May 29, 2008
You can't really "crop" a photo in Illustrator the same way you can in Photoshop. It's not designed for that.
In Illustrator you can mask out an area you don't want. Search the Help pages under "Clipping Mask"
Votes
Translate
Translate
Report
Report
Guest
Aug 14, 2014 Aug 14, 2014
Clipping paths and masks can be temporarily applied, and then released from release (accessible in the objects panel).  This can restrict parts of the image for viewing, or make them viewable again layer.   Here is a link to a video explanation: click here
  1. Go to view --> show edges or use  (control H or cmd H)
  2. Press V on the keyboard (brings up selection tool), then click the picture you are wanting to crop
  3. Somewhere on the screen (probably top), a mask button appears on top of the control panel
  4. Click the Mask button (in that control panel) --> creates a clipping mask
Two buttons at the far left of the same panel that had clipping mask button show up (far most left-two buttons).  after you click the first of those buttons, use (keyboard a shortcut) to start clicking anchor points at the far-most corners of the image
  • After selecting topmost anchor points, use shortcut shift down.
  • You can select any edge (made of at least two of those anchor points (and use shift key + UP DOWN LEFT RIGHT aft)
ANOTHER TRICK= OPACITY MASK
  • Use the shape drawing tools (i.e. ellipse tool) --> then use a white fill color (optimally)
  • Create white circle atop the car (or above the vector artwork)
  • Use V key to select the white ellipse, then shift select the car to select the image behind the ellipse, and then open the transparency option (window panel ==> transparency panel)
  • Within the transparency panel, expanding the menu that appears, and select the make mask button, which allows you to see ONLY WHAT YOU HAVE IN THE FILLED SHAPE or ellipse (as shown in the video linked at the top).
  • you can adjust the mask or the artwork you are trying to restrict and also, you can release any of these clipping masks
Advantages over cropping:
  • In the video, you can actually modulate some property of the clipping mask (say add a gradient and opacity mask), which actually saves you some time by allowing you to not only crop, but change the entire image, and making it easy to release that mask so your raw materials are usually in tact.
Votes
Translate
Translate
Report
Report
Advocate ,
As Kev Say, illustrator don't crop an image, it mask the image
see here migrating to Illustrator
http://www.adobe.com/designcenter/illustrator/articles/illcs2am_creativity.html
see here tutos on illustrator basics
http://www.adobe.com/designcenter/video_workshop/
Votes
Translate
Translate
Report
Report
New Here ,
Sep 30, 2013 Sep 30, 2013
Votes
Translate
Translate
Report
Report
New Here ,
May 31, 2008 May 31, 2008
Cool. Great videos, thanks.
Amazing how sometimes Freehand was sooo much easier.
Mark
Votes
Translate
Translate
Report
Report
Advisor ,
Apr 01, 2010 Apr 01, 2010
Yeah, there is no "Paste into" in Illustrator, you will get used to using masks to crop your photos. I like it a lot better then the way I had to work in Freehand.
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 28, 2015 Feb 28, 2015
Not sure if I am misunderstanding. I am very new to illustrator,but ctrl V pastes into it very well.
Votes
Translate
Translate
Report
Report
Explorer ,
If you use the clipping mask tool, it will "crop" your image, but if you try to export it as a raster file, your dimensions will remain the same as the original photo's dimensions, meaning you will have white space in your jpeg/png/bmp/gif/tif file where your clipping mask is...I've had this problem before, the way I deal with it is...get ready...I use MS paint to easily crop out the white space by pulling the image limiters(little blue dots)to only where my image should show, rotating the image if necessary, and repeating the process until I have my image cropped...no need to go back into photoshop, or even use photoshop.
One of the RARE times when MS paint comes in handy...to be honest, I've never used it for anything else.
Votes
Translate
Translate
Report
Report
Guide ,
If you want to totally eliminate content outside a mask in Illustrator (giving you a true crop), you can use the following method:
Select the path that you would have used for the clipping mask and, instead of making a mask, fill it with, oh, say, white. Then, set the opacity for that masking object to 0% using the transparency palette/panel. Then, with that object and the underlying raster image selected, flatten transparency. (Use 100% vector on the quality slider and make sure the 'Preserve alpha channel' option is unchecked.) Ungroup the result.
You should now be able to independently select the various portions (inside and outside the mask) and discard those you don't need. The links palette/panel will show you what's going on.
You can use this method with multiple clipping masks in a single operation. You don't even have to initially embed the underlying image for this to work.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 15, 2010 Nov 15, 2010
Thanks for this, I've used the clipping masks, but I didn't know how to flatten images. After the clipping mask, I have cropped, then exported as an image file in order to print. For some reason Illustrator couldn't deal with the masks and complicated images below when asked to print.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Nov 02, 2011 Nov 02, 2011
Thank you. I was going crazy trying to do an ordinary crop in Illustrator.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 23, 2011 Nov 23, 2011
Thanks Appleman. That reduced my file size to 1/40...big help!
Votes
Translate
Translate
Report
Report
Guest
May 17, 2012 May 17, 2012
Can adobe Illustrator crop like more images at once to the same size know an option to use ?
thank you , Luka
Votes
Translate
Translate
Report
Report
New Here ,
Sep 19, 2012 Sep 19, 2012
I don't know Illustrator at all, but here is how I did it:
Export the file to Photoshop as a jpg.
Open it it Photoshop.
Crop it.
Simple!!!
Votes
Translate
Translate
Report
Report
But that rasterizes it.
Votes
Translate
Translate
Report
Report
Jul 27, 2012 Jul 27, 2012
This is awesome.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2013 Feb 10, 2013
YES! Thank you. I've been trying to figure this out for around 8 hours. Worked perfectly with a jpg image.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 07, 2013 Mar 07, 2013
Because Adobe Illustrator is a vector-based design system, you can't crop a picture in Illustrator the same way you can in Adobe photoshop. But you can use a clipping mask and opacity mask to crop a picture and photo.
Votes
Translate
Translate
Report
Report
New Here ,
May 12, 2015 May 12, 2015
That's cool ! Thanks
Votes
Translate
Translate
Report
Report
New Here ,
Who is this.
Also you can't, you need to move it into photo shop
Votes
Translate
Translate
Report
Report
New Here ,
Jun 04, 2015 Jun 04, 2015
Great idea.. 🙂
Votes
Translate
Translate
Report
Report
New Here ,
Nov 03, 2011 Nov 03, 2011
Thanks TheMarkness!!! I've always wondered how to take an image from a JPG in CS2 and crop the white space around, your instructions are the clearest I've read! Good ole MS Paint!
Votes
Translate
Translate
Report
Report
New Here ,
Oct 20, 2015 Oct 20, 2015
Aargh I was really hoping to find another answer! Too bad we aren't able to fix it in illustrator although...
I have a little trick that I like to use when I get stuck. What I do:
1. select the image (NOT in a clipping mask. if so, just keep double clicking till you can select the whole image)
2. Image trace. at preset, select the 'Photo High Fidelity' option and then finish your tracing.
3. create a clipping mask (or if you already have one, you can skip this step.)
4. Use pathfinder (I, to be honest, never know exactly which one to use so I just click till I find the right one. But this time, you'll need the bottom left one in your pathfinder screen.)
Votes
Translate
Translate
Report
Report
Community Expert ,
The Links Palette is another option in case we're talking about rectangular crops. A couple of stumbling blocks included.
Votes
Translate
Translate
Report
Report
