7 Replies Latest reply on Oct 30, 2008 9:16 AM by Newsgroup_User
    Need help with sizing content block
    Level 7
      how can i force a content block to a certain height.. i found my issue with
      the white spacing at the top of my last post pages.. to be the amount of
      data on the page.. if there is small amount of content the space is very
      large.. but if i add some <br> tags the space gets smaller until its the sam
      as the rest of the pages.. i rather not clutter my pages with 10 <br> just
      to get the same layout as the rest of the site..
      Any suggestions?
      ASP, SQL2005, DW8 VBScript, Visual Studio 2005, Visual Studio 2008
        • 1. Re: Need help with sizing content block
          Level 7
          sounds like you are putting text in a table cell and not changing the cell's
          vertical alignment. Middle is the default so in a tall cell (propped open by
          content in one or more cells in the same row) minimal text will sit far from
          the top of the cell.
          If that's the case change the cell's vertical alignment to top.
          Walt
          "Daniel" <dan_c@h.com> wrote in message
          news:gea0vc$ei2$1@forums.macromedia.com...
          > with the white spacing at the top of my last post pages.. to be the amount
          > of data on the page.. if there is small amount of content the space is
          > very large.. but if i add some <br> tags the space gets smaller until its
          > the sam as the rest of the pages.. i rather not clutter my pages with 10
          > <br> just to get the same layout as the rest of the site..
          > Any suggestions?
          • 2. Re: Need help with sizing content block
            Level 7
            Actually no tables.. atleast not on these few pages.. its a Visual Studio
            Content block..
            but what i was looking for is maybe a CSS property that i can use with a div
            or span tag to adjust the width and height and force whats inside to stay
            within those dimensions..
            "Walt F. Schaefer" <walt@waltswebworx.com> wrote in message
            news:gea4oa$jl1$1@forums.macromedia.com...
            > cell's vertical alignment. Middle is the default so in a tall cell
            > (propped open by content in one or more cells in the same row) minimal
            > text will sit far from the top of the cell.
            > Walt
            >> amount of data on the page.. if there is small amount of content the
            >> space is very large.. but if i add some <br> tags the space gets smaller
            >> until its the sam as the rest of the pages.. i rather not clutter my
            >> pages with 10 <br> just to get the same layout as the rest of the site..
            >> Any suggestions?
            • 3. Re: Need help with sizing content block
              Level 7
              >>its a Visual Studio Content block.
              HUH? Doesn't sound to me like something that should be in a web page. Did
              you use Visual Studio to write the HTML?
              Link please. This is too vague to go further without seeing the complete
              page.
              Walt
              news:geacom$19u$1@forums.macromedia.com...
              > Content block..
              > div or span tag to adjust the width and height and force whats inside to
              > stay within those dimensions..
              >> Walt
              >>> Any suggestions?
              • 4. Re: Need help with sizing content block
                Level 7
                http://66.162.81.144/cms400min/default.aspx
                Click on employment, then click on Corporate Jobs..
                pay attention to the white space above the menu
                on the main employment page the space is just right.. small think white
                line.. but on the corporate page the space is larger.. if i add <br> to that
                content at the bottom of the page, the space gets smaller.. and i can add
                about 10 or so <br> and the spacing looks the same on both pages, but i
                rather not do that..
                news:geadiq$29f$1@forums.macromedia.com...
                > page.
                > Walt
                >> Content block..
                >>> Walt
                >>>> smaller until its the sam as the rest of the pages.. i rather not
                >>>> clutter my pages with 10 <br> just to get the same layout as the rest
                >>>> of the site..
                >>>> Any suggestions?
                • 5. Re: Need help with sizing content block
                  Level 7
                  Yes there is a table and the element causing your problem is in a cell with
                  vertical-align:middle
                  Walt
                  news:geaens$3ql$1@forums.macromedia.com...
                  > that content at the bottom of the page, the space gets smaller.. and i can
                  > add about 10 or so <br> and the spacing looks the same on both pages, but
                  > i rather not do that..
                  >> page.
                  >> Walt
                  >>> Studio Content block..
                  >>>> Walt
                  >>>>> of the site..
                  >>>>> Any suggestions?
                  • 6. Re: Need help with sizing content block
                    Level 7
                    i found what you mean.. but i changed the 2 references to veritcal-align and
                    made them both Top and still same issue...
                    sorry, i was only looking at my page code and not the masterpage code.. that
                    has the table..
                    this the master page code..
                    any suggestions on changing this code to work better?
                    <div class="bodycont">
                    <form id="form1" runat="server">
                    <div class="logoimg"><a href="default.aspx"><img alt=""
                    src="images/Logo.png" /></a></div>
                    <table class="menulivearea" align="center">
                    <tr>
                    <td id="menutest">
                    <div class="backmenulinks">
                    <asp:ContentPlaceHolder ID="ContentPlaceHolder2" runat="server">
                    </asp:ContentPlaceHolder>
                    </div>
                    </td>
                    </tr>
                    <tr valign="top">
                    <td colspan="5">
                    <asp:ContentPlaceHolder id="ContentPlaceHolder1" runat="server">
                    <CMS:ContentBlock ID="ContentBlock1" runat="server" HorizontalAlign="Center"
                    </asp:ContentPlaceHolder></td>
                    </tr>
                    </table>
                    <CMS:Login ID="Login1" runat="server" />
                    </form>
                    </div>
                    news:geafvb$5co$1@forums.macromedia.com...
                    > with vertical-align:middle
                    > Walt
                    >> can add about 10 or so <br> and the spacing looks the same on both pages,
                    >> but i rather not do that..
                    >>> Did you use Visual Studio to write the HTML?
                    >>> page.
                    >>> Walt
                    >>>> a div or span tag to adjust the width and height and force whats inside
                    >>>> to stay within those dimensions..
                    >>>>> Walt
                    >>>>>> issue with the white spacing at the top of my last post pages.. to be
                    >>>>>> the amount of data on the page.. if there is small amount of content
                    >>>>>> the space is very large.. but if i add some <br> tags the space gets
                    >>>>>> of the site..
                    >>>>>> Any suggestions?
                    • 7. Re: Need help with sizing content block
                      Level 7
                      Walt,
                      thank you very much for the help.. after your suggestions and more searching
                      online.. i found that using your css to make the image sit at the top
                      worked.. and then i used the Background-position to move it down a bit and
                      the spacing looks great across all browsers..
                      NOW...
                      the issue i have if you look Vendor Info, FAQ, Employment pages
                      you will see that my content is left aligned.. i need the content to sit in
                      the middle of th white box and still be left aligned..
                      what am i doing wrong..
                      news:geajgg$a4l$1@forums.macromedia.com...
                      >and made them both Top and still same issue...
                      > that has the table..
                      > <tr>
                      > <td id="menutest">
                      > </div>
                      > </td>
                      > </tr>
                      > <tr valign="top">
                      > <td colspan="5">
                      > HorizontalAlign="Center" />
                      > </tr>
                      > </table>
                      > </form>
                      > </div>
                      >> Walt
                      >>> pages, but i rather not do that..
                      >>>> complete page.
                      >>>> Walt
                      >>>>> inside to stay within those dimensions..
                      >>>>>> minimal text will sit far from the top of the cell.
                      >>>>>> Walt
                      >>>>>>> be the amount of data on the page.. if there is small amount of
                      >>>>>>> content the space is very large.. but if i add some <br> tags the
                      >>>>>>> space gets smaller until its the sam as the rest of the pages.. i
                      >>>>>>> rather not clutter my pages with 10 <br> just to get the same layout
                      >>>>>>> Any suggestions?
