This content has been marked as final.
Show 3 replies
1. Re: INCS4: Smart Text Reflow not so Smart
(Dave_Saunders) Jan 24, 2009 6:05 AM (in response to Tomabcd)Yep. Philosophically, this is one of those sound good features that I wouldn't touch with a ten-foot pole.
In you specific case, could it be that you have keep spread together switched on for the spreads where you're getting the extra pages?
Dave -
2. Re: INCS4: Smart Text Reflow not so Smart
F vd Geest (WA Veghel) Jan 24, 2009 7:19 AM (in response to Tomabcd)I also found that, for some reason it does not work always as expected when you do not limit the function to only master auto text frame pages and auto delete pages is on.
But remember that for non-master text frame (option turned of in preferences) you do need at least two pages that have linked text frames for the auto-insert/delete to work.
What I found is that when I start with more then two pages with linked text (non auto text frame) and auto-delete pages on), the pages DO get removed but, for some reason, sometimes are inserted back when text reflows and sometimes it are not (this is the case in a few documents in wich conditional text is used).
The function always works OK when using auto-text master frames however. -
3. Re: INCS4: Smart Text Reflow not so Smart
Tomabcd Jan 24, 2009 10:07 AM (in response to Tomabcd)Thanks Guys!
Dave, if by "keep spread together" turned on, you meant "Allow Document Pages to Shuffle" turned off, you win the prize! (Same concept, reversed sense). Googling the former led me to the latter.
I had been trying to figure out just what "Allow Document Pages to Shuffle" meant earlier in the day, and left it changed from its default.
I've been playing with it for a bit now, and it seems to be working correctly so far.
Tom
