6 Replies Latest reply on Oct 6, 2006 10:59 AM by Newsgroup_User
    Power On/Off computer
    Level 7
      Hello:
      Is possible to power on or off the PC with Lingo?
      I need to do this for an application.
      thank you
        • 1. Re: Power On/Off computer
          duckets Level 1
          Yes - to power off, use the command shutdown()
          You can't power it on though.
          Shutdown only initiates the shutdown process, so if the user has unsaved files open, they will be given the normal requests to save their work, etc.
          Hope this helps!
          - Ben
          • 2. Re: Power On/Off computer
            Level 7
            Well, powering a computer ON is a bit difficult since no code is running
            on a computer that is off. But you can shut the machine down using
            the shutDown() method. And you can restart a computer using restart().
            • 3. Re: Power On/Off computer
              Level 7
              Hi Anne,
              I had to do the same thing a while ago.
              For powering off, I used: budapi (2 functions for free):
              baExitWindows("shutdown")
              But Lingo should do the trick to as mentioned before.
              For booting the computer I used the BIOS feature reboot on power failure
              (or something like it). You can put a timedswitch between the computer
              and the pc to simulate a power failure.
              Some BIOS-es also have a timed-boot feature working on the internal clock.
              Manno
              Anne wrote:
              > Hello:
              > thank you
              Manno Bult
              manno@xs4all.nl
              • 4. Re: Power On/Off computer
                Level 7
                thank you.
                What I really need is to have a PC server connected to seven PC clients
                (LAN-WIFI) and from the server power on and off each PC client.
                can you help me please?
                thanks again
                "Manno Bult" <removethis.manno@xs4all.nl> escribió en el mensaje
                news:eg38dd$pai$1@forums.macromedia.com...
                > Hi Anne,
                > (or something like it). You can put a timedswitch between the computer and
                > Manno
                > Anne wrote:
                >> Hello:
                >> thank you
                > Manno Bult
                > manno@xs4all.nl
                • 5. Re: Power On/Off computer
                  Level 7
                  Hi Anne,
                  never tried it, but don't some BIOS-es have atleast a wakeup-on-LAN
                  feature? I think this only would get them out of hybernation, but a
                  google search:
                  http://www.google.com/search?num=20&hl=en&lr=&safe=off&c2coff=1&q=%22boot+on+lan%22&btnG=S earch
                  does bring up some results but not too hopefull:
                  http://forums.amd.com/lofiversion/index.php/t48828.html
                  For shutting down I'd really don't know. Maybe the good old MUS sending
                  the director clients a shutdown signal? Must be easier...
                  Maybe someone with more hardware/network knowledge...
                  Manno
                  Anne wrote:
                  > thank you.
                  > thanks again
                  >> Hi Anne,
                  >> Manno
                  >> Anne wrote:
                  >>> Hello:
                  >>> thank you
                  >> Manno Bult
                  >> manno@xs4all.nl
                  Manno Bult
                  manno@xs4all.nl
                  • 6. Re: Power On/Off computer
                    Level 7
                    > thanks again
                    Hi Anne
                    You can also check out PowerOff 3.0 from
                    http://users.pandora.be/jbosman/poweroff/poweroff.htm
                    It does work over tcp/ip, including WOL (wake on lan).
                    And it does accept commandline, so you can use Valentins shellXtra from
                    within director:
                    http://staff.dasdeck.de/valentin/xtras/shell/
                    If you really need to use WOL on wireless, make sure that the cards support
                    it (including the WOL-connector...)
                    It seems like a controlled setup you make. You can boot the pc's as Manno
                    said - when they get power (110/230V), by setting the bios to "boot on power
                    resume". And shut them down the hard way, by taking the power...All that can
                    be done in the electrical setup, e.g controlled by one button. If you have
                    peripherals on some of your pc's in your setup, that takes a long time to
                    boot, and the pc's need them to be alive on startup, you can use a timer for
                    that particular pc, or leave the power on for those items.
