3 Replies Latest reply on Apr 1, 2009 5:21 AM by pyyhtik
    problem/bug with mouse over movieclips
    pyyhtik
      Been facing an annoying problem at here: www.villielain.com
      Different site sections are located in animated objects (mostly glowing) and when you mouse-over them the bottom menubar shows up. The problem is that, when you go fast over multiple objects (for example tv - cross - wall), the menu bar won't go away.
      I've separate actionscript layer for the menu items and can send the original open file if it helps.
      any suggestions? thanks.
        • 1. Re: problem/bug with mouse over movieclips
          logeye
          don't know but you might want to try
          onMouseUp = function() {
          updateAfterEvent()
          • 2. Re: problem/bug with mouse over movieclips
            Justin Putney Level 2
            Issue 1: If the user leaves the Flash area (and moves over to the black html background in this case), Flash doesn't register a RollOut event, because Flash isn't underneath your mouse to capture it.
            Issue 2: Another problem is that when you display a new menu, your code should remove or override any menu that's currently displayed, rather than just adding a new menu to the stage or making a new item visible.
            Issue 2 can be fixed with some improved code. Issue 1 is a Flash (AS2) limitation, but there are some workarounds. You can start a timer when a button is rolled over. If no rollout event is triggered after the designated time has elapsed, you can check the location of the mouse and perform a hit test with your button. Solving issue 2 will also reduce the occurrences of issue 1.
            • 3. Re: problem/bug with mouse over movieclips
              pyyhtik Level 1
              thank you logeye and Justin!
              I'll try to follow your leads justin. I hope i can get it worked out!
