0 Replies Latest reply on Oct 29, 2008 7:27 PM by etnot96
    Fx Webservice Introspection wizard bug
    etnot96 Level 1
      It seems the Fx Webservice Introspection is not interpreting the wsdl correctly. By using TCPMonitor I was able to capture my soap request from my java spring-ws junit test. The correct response is as follows:
      <SOAP-ENV:Envelope xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/">
      <SOAP-ENV:Header/>
      <SOAP-ENV:Body>
      <ns4:ProcessChucksPick3LotteryNumberRequest
      xmlns:ns2=" http://www.chuckspick3.com/WebserviceClient"
      xmlns:ns3=" http://www.chuckspick3.com/lotterysystem/common-schemas"
      xmlns:ns4=" http://www.chuckspick3.com/lotterysystem/schemas">
      <ns2:webServiceClient>
      <ns2:id>0</ns2:id>
      <ns2:customerName>test</ns2:customerName>
      <ns2:customerUserName>test</ns2:customerUserName>
      <ns2:custoemrPw>test</ns2:custoemrPw>
      </ns2:webServiceClient>
      <ns3:chucksPick3LotteryNumber>
      <ns3:number>345</ns3:number>
      <ns3:requestDate>2008-10-29T20:32:37.171-05:00</ns3:requestDate>
      <ns3:drawingType>MidDay</ns3:drawingType>
      </ns3:chucksPick3LotteryNumber>
      </ns4:ProcessChucksPick3LotteryNumberRequest>
      </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      Using the code generated from the Fx Webservice Introspection wizard I get the following invalid soap request:
      notice that there are no namespaces specified.
      <SOAP-ENV:Envelope>
      <SOAP-ENV:Body>
      <tns:webServiceClient>
      <tns:id>1</tns:id>
      <tns:customerName>test</tns:customerName>
      <tns:customerUserName>test</tns:customerUserName>
      <tns:custoemrPw>test</tns:custoemrPw>
      </tns:webServiceClient>
      <ns0:chucksPick3LotteryNumber>
      <ns0:number>234</ns0:number>
      <ns0:requestDate xsi:nil="true"/>
      <ns0:drawingType>Day</ns0:drawingType>
      <ns0:type>Customer Provided Winning Pick 3 Lottery Number</ns0:type>
      </ns0:chucksPick3LotteryNumber>
      </SOAP-ENV:Body>
      I think there is a bug in the code generated from the Fx Webservice Introspection wizard. You can download or view my wsdl by clicking here.
      If this is not a bug, can some one please tell me what I am doing wrong.
      I hope someone will respond to this post as I really want to use flex for webservices; but have not been successful.
      Thanks!
