3 Replies Latest reply on Nov 3, 2008 11:51 AM by LeeBC
    Dreamweaver cs3 error on file open
    desalvatore.com
      Suddenly getting an error when I open a file:
      error signature:
      AppName: dreamweaver.exe
      AppVer: 9.0.0.3481
      ModName: dreamweaver.exe
      ModVer: 9.0.0.3481
      Offset: 002dab57
      Any body know what this is? Was working fine on friday, no changes to extensions or updates, came in this morning, and the error started.
        • 1. Re: Dreamweaver cs3 error on file open
          Level 7
          Has to do with time change
          Try this:
          1. Closing Dreamweaver
          2. Set your clock to the correct time if it isn't already so
          3. delete WinFileCache*.dat from
          C:\Documents and Settings\[Your username]\Application Data\Adobe\Dreamweaver
          9\Configuration
          4. Start Dreamweaver and use it as usually
          "desalvatore.com" <webforumsuser@macromedia.com> wrote in message
          news:gen3ia$c22$1@forums.macromedia.com...
          > error signature:
          > AppVer: 9.0.0.3481
          > ModVer: 9.0.0.3481
          > Offset: 002dab57
          • 2. Re: Dreamweaver cs3 error on file open
            desalvatore.com Level 1
            That worked!! Thank you!!!
            • 3. Re: Dreamweaver cs3 error on file open
              LeeBC
              I was having a problem doing any editing on certain files and could not figure it out whatsoever. I happened to come upon this answer, although I could open the file, but could not edit it. So, I followed these instructions, and thank goodness, it worked. Is there an update or fix to this because if I do not purchase the most current CS package, I will have to remember to do this every time change. I am happy it only took 2 hours out of my day, considering that I could have been knocking my head against the wall for days. Was going to download back up files and everything thinking they were corrupt or start typing code - these were rather large CF files.
