2 Replies Latest reply on Oct 9, 2009 4:53 PM by Konrad.Gmurek
    Disable HTML Text Selection
    King Wardrop
      Is this at all possible? I want to disable the ability for users to select text in certain elements of my HTML AIR Application. I want to keep things like buttons and text links click-able though, so overlaying something like a transparent PNG wouldn't work too well.
        • 1. Re: Disable HTML Text Selection
          Does anyone found a solution to this?
          I am facing the same problem.
          I have disabled contextmenu, but after user selects a text, on right-click "copy" menu is visible.
          Please help
          • 2. Re: Disable HTML Text Selection
            I was looking for a solution to the same problem and found only this thread.
            After a few tests and researches I've found how to do this and it seems to be fairly easy.
            To avoid selecting text an element should have css attribute "-webkit-user-select" set to "none" (this is WebKit's equivalent for css3 user-select). The only thing left to do is to set cursor's shape to "default" or "pointer".
            html {
                 -webkit-user-select: none;
                 cursor: default;
