1 Reply Latest reply on Jan 29, 2008 2:24 AM by (Peter_Schülke)
    pictures appearing as grey boxes through preview of EPS
      What we do here is create indesign cs 3 documents and send them to our cs 3 indesign server computer which then generates an eps and pdf of the document. What we're seeing is that after the eps and pdf is generated our preview option from our program, the EPS is showing up with grey boxes for 95% of the images on the document. If we manually open the EPS it appears fine (I'm assuming it must be an issue with the images and generating the preview on the eps).
      If I generate the pdf/eps locally on the computer running indesign CS 3, the preview displays fine for all the images.
      I'm wondering if there is a way to check the eps settings and more specifically the preview settings being generated with the EPS on indesign cs 3 server. Any help would be appreciated, and if you think it could be something else happening, I'm all ears.
