1 Reply Latest reply on Oct 28, 2008 8:02 PM by (Bill_Gaitz)
    Slow access on Network-folders
      Hello forum,
      I have a big problem with the speed of Indesign Server, when i try to access a Network path.
      The Server is running and gets a script via SOAP and everything is working well, except the speed. Within the script i open a document, which is placed in a network folder :
      (Command: doc = app.open("\\\\server-ip\\path\\file.indt");
      This process lasts almost 10 seconds, and after that, everthing runs fast.
      When i place the file on the local machine, the script runs in less then a second.
      It is only slow at the first time i access the network path (within the one script), i.e. when i place a file from the network with 'doc.place()' after the opening, it is fast.
      I use Windows Server 2003 32bit, Indesign Server CS3,
      and the files are on a SuseLinux 10.1 with Samba.
      help would be welcome
      Michael Rupp
