3 Replies Latest reply on Aug 27, 2008 12:14 AM by Mfi Previon
    Indesign CS3 Server, .Net and cyrillic
      I'am trying to develope a Silverligt Interface for Indesign Setrver and using SOAP as a protocol between IDS and .NET. Everyting works fine (even German Umlatus) until i try to send a cyrillic text.
      One example:
      I'am sending "абвгд" and IDS creates text with content "01234".
      I thought .Net sends the content incorrect, that'swhy i opened the SOAP Envelope - the text was correct. I wrote "абвгд" inside the .jsx-file which create a PDF file - IDS created correct again.
      Maybe there is anybody, who had the same problem a can help me.
      Kind regards,
      Petar
        • 1. Re: Indesign CS3 Server, .Net and cyrillic
          Hi Petar,
          Sounds like a font issue. Can you open InDesign and type out "абвгд?" Do you have the proper fonts on the server to render those characters?
          Eric
          • 2. Re: Indesign CS3 Server, .Net and cyrillic
            Level 1
            Hi Eric,
            i attempted to create a Silverligh application which fill the visit card form the IndesignServer Tutorial Page (http://www.adobe.com/devnet/indesign/training/tutorial3_2007_apr/)
            Here is the extraction of the JavaScript file
            // looks not good
            // insted of абвгд is 01234 saved in the card.indd
            myDoc.xmlElements.item("Root").xmlElements.item("card").xmlElements.item("name").contents = app.scriptArgs.get("name");
            // if i try this looks great
            // абвгд will be saved in the file
            myDoc.xmlElements.item("Root").xmlElements.item("card").xmlElements.item("name").contents = "абвгд"
            myDoc.save(new File("C:/test/card.indd"));
            app.documents.item(0).close();
            // Indesign Server prints 01234
            // Indesign prints ?????
            // but its ok because i have Win2008 EN Server
            "абвгд";
            so i thought .Net send incorrect SOAP code, but if i save ( with help from PHP and print_r($HTTP_RAW_POST_DATA )) i can see that Silverlight/.Net sends correct.
            I'm using Adobe InDesign Server CS3 Release WIN (Multilang) on one Windows Server 2008 English machine. I think there is no problem with the fonts, because i can save indd-files with cyrillic content (myDoc.xmlElements.item("Root").xmlElements.item("card").xmlElements.item("name").content s = "абвгд")
            I can open InDesign CS3 Tryout (the desktop version, not the Server) and type cyrillc too. It's everything correct.
            Mabye you have any ideas?
            Thanks and regards,
            Petar
            • 3. Re: Indesign CS3 Server, .Net and cyrillic
              Mfi Previon
              Hi Petar,
              Maybe this post will help:
              http://www.adobeforums.com/webx?128@@.3bc25ac6
              Kind Regards,
              mfi
